| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
Major electrical problem
My son has a 95 talon esi...The last time we started it all the guages went wacky...and it died and wouldnt start. All the warning lights went on and off and the right side cooling fan came on. I messed with the foot feed and could hear the fan speed up as I depressed the foot pedal.
I also noticed that the throttle cable the was attached to the intake was sparking and getting hot. I unhooked the cable and started taking off harness conections to see if I could pinpoint the short. nothing worked. I finally cut a piece of gasket material and placed it under the throttel cable link that was on the intake so it would not ground to the intake. No more sparks but car will not start. It will roll over but not getting any spark. The guage lights will not light up now. I'm at a lost at what to do or where to look. |
Re: Major electrical problem
check your fuses, you might have blown one when the throttle cable started sparking
98 Eclipse GS Turbo Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio 1981 Chevy Scottsdale 1987 Nissan 300zx - Chump Car 2001 BMW 325i - DD |
check out the battery, it might be fried. also check ALL the fuses, twice if you have too.
Re: Re: Major electrical problem
Thanks I finally figured out that is was a bad ground...I took a set of jumper cables and connected them to the neg side of battery then one to the engine and one to the body....everything worked... I just ran a new ground from the battery to the body to solve the problem. |
Thx for posting the solution.
'92 3000gt SL Zoom Stage 1 Clutch Quote:
