Old 10-04-2005, 09:47 PM
91 Eclipse 91 Eclipse is offline
Send a message via MSN to 91 Eclipse
Rich or lean
As most of you know i just got my turbo in the GS eclispe and now i need some help. if i just use my NT ECU will i bee running rich or lean and if i use my NT injectors would that happen at all.
91 Eclipse GS 5-Speed 2.0L DOHC 16 Valve (Black)
Stock
93 Eclipse GS-T 5-Speed 2.0L DOHC 16 Valve (Red)
Cosmo Racing Air Filter
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
Megan Racing 3" turbo back exhaust
450cc Injectors
I am selling my 1993 GS-T eclipse for 3000 obo. it has a new engine with 15,000 on it, brand new 3" turbo back exhaust, Brembo rotors, and NEW Faze A/F gauge and Boost/Vac Gauge. will post pics as soon as I can PM if interested
Old 10-04-2005, 10:22 PM
milton666's Avatar
milton666 milton666 is offline
Send a message via MSN to milton666
Re: Rich or lean
i would think your ECU would adjust for the new amount of airflow so i dont think thatd be a problem but dont hold me too it, but whats the flow on stock gs injectors? just compare the flow on those to those on a stock gst or gsx and see if its the same.
95' Gs-t (broke the fuck down...)
68' Mustang getting reassembled right now, 82.763% done
http://www.tagworld.com/milton666
Old 10-04-2005, 10:23 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: Rich or lean
O boy
I'm not trying to talk down to you, but honestly, if you didn't know this kind of stuff, you had NO business turbocharging your car until you did. Think about it, now that you're turbo you are sending in gobs of air that your fuel system can't handle. If you did upgrade your fuel then great, but now you have no way of monitoring it. Even if you can monitor, do you have the tuning equipment to make necessary changes? Without the proper turbo setup your car will be toast. I hope you work it out before it does. Good luck
now - 2000 civic
soon - 2002 is300
Old 10-04-2005, 10:26 PM
milton666's Avatar
Re: Rich or lean
yea i didnt even think of fuel either you should also check on how much your fuel pump flows vs a turbo model fuel pump, and i would highly recomend getting something for tuning like crunchy said so you can monitor all this stuff
Old 10-04-2005, 10:53 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
You obviously won't be running rich. You need to get some sort of tuning device and upgrade your injectors, because chances are you will be maxing them out if you run any type of boost at all.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 10-05-2005, 07:01 AM
Re: Rich or lean
i am gonna be running minimal boost for now i got gauges and all the stuff to read fuel and air and i got a boost gauge im waiting on a boost controller, i am gonna get stock turbo injectors for a junkyard and i am getting a walbro 255 i think. does that sound about right. i know quite a bit about turbos and how they all work i have evrything in my car i am just waiting on my downpipe and money to get injectors and a fuel pump. i mihg tget a stock turbo fuel pump for now from the junkyard also.
Stock
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
450cc Injectors
Old 10-05-2005, 08:12 AM
If you can get them really cheap, then go for it. If not, don't waste the time and money. Get the good shit the first time.
"Mod Cheap, Mod Twice"
'92 3000gt SL
Zoom Stage 1 Clutch
Old 10-05-2005, 06:03 PM
Re: Rich or lean
Before you even think about firing up that car, please get a logger and a air/fuel controller. I know you have gauges, but that's not enough. A blinky A/F gauge will only tell you is you're WAY off and about to blow the engine.
now - 2000 civic
soon - 2002 is300
Old 10-05-2005, 06:24 PM
Re: Rich or lean
i am getting 450cc injectors today, and 255 fuel pump and a fuel pressure regulator next week sometime. i am gonna wait on the S-AFC for a little bit cause i think that the fuel pressure regulator will do fine for now correct me if im wrong. i am currently looking for a job so then more mods will come. i dont plan on having my car in operation for a couple of weeks yet so i got time.
Stock
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
450cc Injectors
Old 10-06-2005, 02:35 AM
Re: Rich or lean
You are incorrect that the fuel pressure regulator will fix anything, it will just keep the walbro255 where it should be. Think of it like this, the 450 injectors are like a water hoses and the stock NA injectors are like straws. Even at the correct fuel pressure you will run way off in your fuel trims.
What are the NA injectors in cc's?
Wait a few more weeks, try to find a used s-afc. The regulator will not help this, it will just keep the walbro under control!
now - 2000 civic
soon - 2002 is300
Old 10-06-2005, 06:50 AM
Re: Rich or lean
yeah i found that out last night. if i remember right the stock NT were really low so im gonna replace them just incase. so if i am right this is what i need please add anything i might still need. 450cc injectors, walbro 255 fuel pump, S-AFC, Fuel Pressure Regulator anything else???
Stock
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
450cc Injectors
Old 10-06-2005, 05:48 PM
Re: Rich or lean
a logger should be #1 on that list. But then again, I have no idea what you have and what you don't.
now - 2000 civic
soon - 2002 is300
Old 10-06-2005, 06:20 PM
Re: Rich or lean
well for now i have a completely stock 14b turbo set up. but i will get the injectors first then Logger, then S-AFC, then Fuel Pump, then FPR and that should be good that will run me about 600 dollars so i would have to wait for anyting else. this will hopefully all get done in the next couple of weeks not to mention i dont even have my license yet. i am 16 but i act 21 and everybody thinks i am but anyway. so i can get my license whenever i want, so just waiting for me to go get them. i have a little time yet
Stock
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
450cc Injectors
