ticking
hey my 91 305 has a ticking noise and my dad said it could be the distributor cap b/c mine is no good how can i fix a spark tick, or could it be sometyhing else please help
Re: ticking
My alternator ticks on my car for some reason. It still works fine just got used to the noise.
ASE Master Certified before the age of 20 Current Cars: 2001 Chevy Silverado 1500 Z71 5.3L 1996 Acura Integra LS B18 1.8L Past Cars: 1990 Buick Estate Wagon 5.0L 1987 Chevy S10 2.5L Tec Four 1995 Pontiac Grand Am 2.3 Quad 4 1996 Jeep Grand Cherokee Limited 5.2L AWD 1991 Ford Tempo L 2.3L 1992 Buick LeSabre 3.8L 1997 Buick Century 3.1L 1996 Lumina APV GT 3.4L 2006 Ford Escape 3.0L XLT |
Re: ticking
it could be a couple extra things such as a loose or too tight rocker, or it could be a stuck valve, or a loose timing chain.
Re: ticking
You said your dad said it was the distributor... mine does the same thing at idle when its in drive. Its somewhat common. If its not a lifter tick (look into that) or a manifold tick then don't worry about it.
a common problem is a broken exhaust manifold bolt or a cracked exhaust manifold
Formerly Blownalcoholboy 1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi) Best ET 1/4: 8.35 @ 170mph (275 drag radial) Best ET 1/8: 5.44 @ 132mph (275 drag radial) Best 60': 1.31 on the back tires (275 drag radial) AF User Rules/Guidelines http://www.automotiveforums.com/vbul...uidelines.html |
