Go Back   Automotive Forums Car Chat > Kia > Sorento
Old 10-04-2005, 09:45 PM
claw1234 claw1234 is offline
Sorento Blues
Hi all
I noticed im not the first to suffer from a sheared bolt on the pully connected to the crank. To make things worse the mechanic could not get the sheared bolt out of the crankshaft. He then tried to drill it out and apparently the shaft is softer that the bolt and as he waivered a bit ,he damaged the crank. They cant decide wether or not to replace the crank or the entire block. 8 burnt head lights in 2 years, a seat that feels like its been crushed (54000kms)by an elephant,serious wheel vibrations when braking. It does look good and is fun to drive ..so fucking what!!!!.Im really regretting this purchase ..WATCH OUT.
Old 11-11-2005, 10:51 PM
FamilyManOfFive FamilyManOfFive is offline
Talking Minor Concern?
Sounds like you got one of those once in a lifetime engines... Contact Kia and get a new engine (UNDER WARRANTY) IF you are the original owner. Then find a real Kia technician to replace the bad alternator (Producing too many amps/voltage.).
I WAS a GM Truck owner.
JP
Old 12-19-2005, 08:21 PM
KMG9185's Avatar
KMG9185 KMG9185 is offline
Send a message via AIM to KMG9185
Re: Sorento Blues
Originally Posted by claw1234
Hi all
we at the dealer cant order just a crank to put in a engine...we can only get a short block or a long block....... they wont even tell us the torque specs on much of the internal engine and i am a technician for them.....they are strict with thier engines and transmissions....
Kevin
Old 03-14-2007, 06:18 PM
wilde1j wilde1j is offline
Re: Sorento Blues
Wheel vibration when braking is due to warped rotors, a common Sorento problem. If the truck is still under warranty, I'd lean on the dealer. If not, get four US made aftermarket rotors and you'll be good to go for a long time.
Old 05-17-2007, 05:18 AM
suyt suyt is offline
Re: Sorento Blues
wow this one went everywhere.
warped/pulsating rotors common on any car line.
sheared crank bolts THIS is new to kia,but is a posted tsb ALONG with specs.as well as other torque specs for internal engine parts.yes transmissions the techs not aloud to get into.
