Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '91 - '96
Old 10-04-2005, 10:34 PM
ACFREE ACFREE is offline
Question 91 JETTA gl 1.8 SHUTSOFF AND WON'T START UNTIL 10 MINUTES OR MORE LATER
s
I Just Purchased This Car 3 Days Ago. It Sat For About 6 Months. Just 10 Minutes After Driving Off From Buying It, The Car Shutoff. Lucky For Me I Was In Front Of A Gas Station And Was Able To Push It And Look For The Problem That I Could Find. Since Then The Car Has Shutoff Twice And Didn't Start Up Right Away, And It Shutoff 2 Other Times. I Am Planning To Change The Fuel Filter And The Dirty Air Filter. Has Anyone Out There Had This Experience? If So How Did You Fix It?
Thanks In Advance
Acfree
Old 10-07-2005, 11:49 AM
create38 create38 is offline
Re: 91 JETTA gl 1.8 SHUTSOFF AND WON'T START UNTIL 10 MINUTES OR MORE LATER
i had a similar problem-doe the car restart after cooling off
if so it could be the igniton coil or crank sensor
make sure its a current electric problem and not a fuel to engine problem-a mechanic can at least tell u that much without even charging you
