Old 10-04-2005, 06:17 PM
aton304's Avatar
aton304 aton304 is offline
help!!!??? putty went wrong
help please!!
i am working on a revell civic hatch. i tried to fill in the part where the sunroof was and primered it. it appeared to be nice and neat, but after i painted it with tamyia racing white, you can see where the sunroof is. it is like the area sank a little. i can only see 3 options ahead of me:
1. strip the car and start over
2. add more putty and primer over the paint and paint again
3. leave it as is and chalk it up to a learning experience.
any suggestions. i am not sure how to upload photos or insert photos, but i do have a few pics that kinda show what i am talking about.
thanks
Old 10-04-2005, 06:23 PM
NISMO400R's Avatar
NISMO400R NISMO400R is offline
Send a message via AIM to NISMO400R
Re: help!!!??? putty went wrong
strip the paint on the roof and work the roof again.
Future build. My skyline model #20-#24.
Hey, Come to my website for more Skyline model.
Click Here!<-- New address.
Old 10-04-2005, 06:36 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
What kind of putty are you using?
Strip it, fill the sun roof with styrene instead, smooth the gaps with a two part putty. Then before primer, coat with a sealer, then primer, then paint.
-Mike
Old 10-04-2005, 07:19 PM
aton304's Avatar
thanks for the advice. i did fill the hole with styrene then used tamiya putty. i still seemed to sink around the styrene after painting.
Old 10-04-2005, 08:33 PM
MidMazar's Avatar
MidMazar MidMazar is offline
Re: Re: help!!!??? putty went wrong
Your problem is you didn't use a sealer like mike stated, putty, sand, sealer, primer, paint
In Progress
Old 10-04-2005, 08:44 PM
g00eY's Avatar
g00eY g00eY is offline
to upload photos you can either use your automotiveforums.com gallery(way top of page, click on gallery) or find a image hosting site(plenty out there, i use photobucket, but it's pretty slow). the to insert pictures click on "Go Advanced" when you reply. look for a dropdown box that says [font]. under the dropdown box(not in it, just under it) there is a yellow icon with what i asume to be mountains with like some sort of moon or sun or something. click on that. insert your picture's web adress. or you could just type [img]url here[/img].
about your problem: you should probably just do what the others say, i'm not expert on putty either.
Old 10-06-2005, 04:55 AM
Diesel2NR's Avatar
Diesel2NR Diesel2NR is offline
Send a message via AIM to Diesel2NR Send a message via Yahoo to Diesel2NR
What do you guy's mean by sealer? Like an automotive Primer/Sealer or what?
Old 10-06-2005, 06:38 AM
mike@af's Avatar
There are sealers, and there are primers. Sealers seal the surface to be primed. This is mandatory when doing body work. When a plastic model is primed, it absorbs and expands, whereas the putty doesnt. The sealer will seal the entire model to avoid ghost lines with the putty. So after doing body work, use a sealer then a primer.
-Mike
Old 10-06-2005, 07:00 AM
ZoomZoomMX-5's Avatar
Bodywork "ghosting" is a big problem w/many lacquers, it probably is more prevalent than simple putty "shrinkage" and it's probably what happens when many have said the putty shrank. If you use a two-part putty the shrinkage is minimal and stops as soon as the putty has hardened. If you use any lacquers to paint the model you will get ghosting which makes your filled areas appear shrunken, because the plastic around the filler has expanded from the lacquer and thinners. It can get bad enough that anything you shaved off the plastic (mold lines, emblems, door handles) can "reappear" when the model is sprayed w/lacquers. Sometimes it doesn't appear until after that really nice wet clearcoat. Very annoying
Use a sealer. Many people use Dupont Variprime, an expensive and very toxic sealer that requires an airbrush and heavy duty breathing apparatus. They claim it works. I've been able to "beat" it, and make the plastic ghost under it. But I'm impatient.
Sand your roof smooth (hopefully you won't need to strip the paint), apply some Zinsser B-I-N primer/sealer (available at Home Depot/Lowes) and then prime/paint over it. Make sure there's a complete layer of primer or paint under it as well, it doesn't stick well to plastic. But it seems to do a good job of sealing plastic from lacquer damage aka "ghosting".
My Fotki Album
