Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 10-04-2005, 05:59 PM
exhausted exhausted is offline
Send a message via AIM to exhausted Send a message via Yahoo to exhausted
Question 95 Civic Ex Next Upgrade
Looking for suggestions
got a 95 civic ex with:
intake
a'pexi RS (pre-ws) exhaust
upgraded spark wires
was thinking about getting headers next
and then air/fuel management controller
what should i install next?
Old 10-04-2005, 06:19 PM
wakeboard_dude5 wakeboard_dude5 is offline
Send a message via AIM to wakeboard_dude5
get quality headers and a REAL free-flow cat (Magniflow, carsound, ect. and not just resonator off ebay). air'fuel controller useless, you wouldn't need it anyways.
If i were you, i'd start spending my money to work on suspension. Lowering, sway bars, strut bars. Make it corner like no other. But it's not up to me, its all what you're going for. If its speed, save up for a B-series swap or go turbo. if you go either of those ways there's no need for a header because you'll have to change it with either of those routes. Do as many search's as you can, you'll find tons of info all over this site.
1993 civic EX coup auto SOLD! but i'll miss her
1996 Civic CX w/ B18c1 swap, small bolt on's, 2000 front end
Old 10-05-2005, 10:20 AM
yeah i have eibach springs in there.. 5zigen rims but i do need to get a pair of sway bars...
hmm.. does getting a turbo kit alter what kind of headers you need??
Old 10-05-2005, 12:13 PM
yes, you will need a very rare header off of a GMC Yukon, just the drivers side one. From there, you must cut it, resize, drill holes, than see if it lines up. Before asking about turbos....try searching. There's tons of info out there that would answer all your questions. If you go turbo you can get some kits that have everything you would need or you can piece it all together. But be prepaired to spend atleast $2000 for a good set up.
Old 10-05-2005, 03:49 PM
just got the apexi exhaust on, its weird.... it responds better to inital acceleration.... before i had it on, it had more pull when shifting gears?
any ideas why??? did i lose HP??
Old 10-06-2005, 12:09 AM
the pipe diameter is probably big so you're loosing what little torque you have. Could have slight HP gain, but torque is the kick you've felt.
Old 10-06-2005, 05:45 PM
Re: 95 Civic Ex Next Upgrade
damnit, the assclown that owned the car before told me that he had good suspension in there. I took it to the alignmentr shop and they said it needs a camber kit on the front and back.. so the fucking alignment has been off since i bought it and since he lowered it... also the fuckin moron wired the audio system backwards and used cheap cable.... getting pissed..
Otherwise performance wise..i had more of a chance to try the new exhaust out... actually the high end rpm pull is about the same .. a hell of a lot more pull from inital acceleration... before it would take forever..
still pissed about the sus[pension though....its all rattly on the road..has new tires and alignment.
Old 10-06-2005, 07:14 PM
tomsindahizouse tomsindahizouse is offline
Send a message via AIM to tomsindahizouse
ok...so back to the GMC Yukon Header. make sure that you wrap it up with heat tape before you install it. with the turbo its gonna get really hot under the hood.
2000 Civic Si
98 Civic Dx
Old 10-06-2005, 07:30 PM
"f"that .. . . .ill just buy som DC headers for $400 .. . .
Ceramic or steel???
I would think that steel retains heat more than ceramic
but i might be wrong
Old 10-06-2005, 08:58 PM
go with the ceramic. you do know the yukon thing was just a joke...right?
2000 Civic Si
98 Civic Dx
Old 10-06-2005, 11:30 PM
haha ya, the thing about the yukon was just a joke. Correct me if i'm wrong, but retaining heat really doesn't matter that much. I believe its about how well it flows. i got a DC 1 piece ceramic 4-2-1 header and it seems to work just fine for me. I believe that style header is the "best overall" header. And what size rims do you have? that could be why your suspension seems all rattly. or... you could just be driving on bad roads
Old 10-07-2005, 10:31 AM
Yeah, I was kinda ignoring the Yukon idea... just sounded like a bad idea.. funny joke though.
Naww, the two new tires on there must not have been balanced properly.
but still , the car needs camber kits.
Old 10-08-2005, 02:33 AM
tires mean nothing. the bigger the rim the harder the ride because there is less width between rim and surface which = less cushion
