Old 10-04-2005, 01:59 PM
Telfer61 Telfer61 is offline
Question Cavalier Will Not Start in Hot Weather
I have a 95 Cavalier and when its 83 degrees F or hotter my car will not start. It turns over but it will not spark. I've replaced the plugs, wires, coils and even the fuel filter but nothing seems to help. If anyone has any ideas, they would be greatly appreciated.
Old 10-04-2005, 02:21 PM
cdru's Avatar
cdru cdru is offline
Re: Cavalier Will Not Start in Hot Weather
You need 3 things for the engine to start: fuel, air, and spark. Figure out which of the 3 you don't have. It's a fairly safe assumption that you have air.
Vinyl adds horsepower, right?
Old 10-04-2005, 04:50 PM
lostconcept lostconcept is offline
Send a message via MSN to lostconcept
you try jumping it yet? if not youre bat could be dead, mine was the same yesterday turned over just wouldnt start, then i jumped my car and let the alternator charge my batt a bit, works good now
Old 10-04-2005, 07:47 PM
The battery is new. The car runs fantastic when the weather is cool; it just willl not start when it's hot outside.
Old 10-07-2005, 10:42 AM
noshun's Avatar
noshun noshun is offline
it's turning over and not firing. when you turn the key, turno it all the way until the click just beofre starting when all the ligths are on on the dash and then see if you can hear the fuel pump priming. if not it's going something to do with probably them pump, but try switching the fule pump relay with the a/c relay (if you have it) and see if that makes a difference! I doubt it's battery, your car is turning over after all. you could check for spark by removin the fuel pump fuse or relay before putting thr key in the ignition. put the key in the ignition and then turn the car over for about 5 seconds, turn off, remove a spark plug, put the spark plug into its wire and then get someone to turn the car over and the touch the thread of the spark plug to the block, if it sparks then it's fuel. this wont work if you have the 2.3 twin cam though. it sounds like there is a crack in the coil pack housing. and when hot it expands. this is something i've come accross before.
Red Z24 = Dead, 03 2 door = 15.5 with no traction. low 15's here i come
'Never forget Grasshopper, Not speed, smile!'
