Old 10-04-2005, 01:17 PM
95xjsport 95xjsport is offline
Send a message via AIM to 95xjsport Send a message via Yahoo to 95xjsport
starter button
would anyone know how to hook up a start button? I found one at walmart rated for 60 amps but, no directions, would 60 amps be strong enough?
Black 99 Jetta GLX VR6
Black 92 BMW 525I
Blue 95 GMC Jimmy SLT 4.3L VORTEC V6 (Sold... Junk)
Green 98 Jeep Cherokee SE (totaled Electrical fire)
Red 95 Jeep Cherokee Sport (Gone)
Green 93 Jeep Grand Cherokee Limited (for sale)
[email protected]
"Racing a ricer is just like competing in the special olympics, even if you win your still retarded"
Old 10-04-2005, 06:41 PM
JDPascal JDPascal is offline
Re: starter button
That would depend on what you were trying to accomplish with the added button. Is it added security with a hideout button, replacing the key?? or what other??
Since you are only carrying the current the ignition switch would carry, that rateing should be more than enough. The pull in winding of the solenoid should draw no more than 15 amps (hope I'm safe with that cause it's been a while since I tested a pull in winding). Most of the newer Jeeps use a starter relay between the key and the solenoid on the starter that would reduce the draw thru the ignition switch as well.
JD
Old 10-04-2005, 11:19 PM
Re: starter button
I still want the key to work but, I have a tendency to misplace my keys at home, and need to find them in a hurry so I wanted a backup way to use my jeep, plus I think it would be kinda cool to have a starter button, like the new lexus has. I know the wire that goes to the starter coil thing from the ign switch is atleast 10 or 12 gauge, it is a pretty thick wire...
Black 92 BMW 525I
[email protected]
Old 10-05-2005, 01:55 AM
Re: starter button
Won't you still have a problem if you don't have the key? You'll need to unlock the steering column won't you? Other than that small detail you could do it with a hidden toggle switch plus the starter button.
JD
Old 10-05-2005, 04:25 PM
normally I would but, the steering colum lock dosn't work, actually neither does my shift lock, I can take it out of gear with or without the key... how would I fix the shift lock thing?
Black 92 BMW 525I
[email protected]
Old 10-06-2005, 10:21 PM
Re: starter button
I've not been into the auto transmission shift lock mechanism but the steering wheel lock you likely have to get fairly deep into the steering column.
Someone else may have better insights into those areas.
If you want to be able to start it with either the key or the starter button, you will need a toggle switch to do what the key does in the on position.
It would take some planning but it should be do-able with a few more parts than just the button you already have.
JD
Old 10-06-2005, 10:45 PM
Re: starter button
I have a remote start and all that does is energize the ignition wire which I think is orange, and the starter which is the purple wire, all I would need to do is connect the orange and red wire with the switch which would be the run position and the purple wire with power to the starter button. How big of a switch do you think I would need to power the ignition circuit? T have a 30 amp toggle switch would it be big enough?
Black 92 BMW 525I
[email protected]
Old 10-06-2005, 10:50 PM
Re: starter button
thirty amp rating should be lots big.
How would the auto shut down work out when you don't have the key in the ignition. Do the connections you describe bypass that part of the system??
JD
Old 10-07-2005, 01:01 AM
Re: starter button
it just cuts power to the ign circuit
Black 92 BMW 525I
[email protected]
Old 10-07-2005, 07:32 AM
89ltd 89ltd is offline
Re: starter button
are you talking about a 95 cherokee, or is it something else?
Old 10-07-2005, 02:19 PM
Re: starter button
its for my 95 cherokee
Black 92 BMW 525I
[email protected]
Old 10-07-2005, 02:24 PM
Re: starter button
wait, what is the auto shut down??
Black 92 BMW 525I
[email protected]
Old 10-07-2005, 04:17 PM
Re: starter button
Most remote start units I've seen shut off the engine if you put them in gear without the key in the ignition when you go to leave after warmup.
Prevents theft of idling, remote started vehicles.
JD
Old 10-07-2005, 10:25 PM
Re: starter button
mine has auto shutdown then, it dies when you touch the break or excede 3000 rpms, the shutdown for the starter button though should be the toggle switch...
Black 92 BMW 525I
[email protected]
