Old 10-04-2005, 11:02 AM
peterhiggs peterhiggs is offline
Send a message via MSN to peterhiggs
escort not holding water
when i put water into mr radiator,the water just pours through and leaks under the gearbox,can anyone tell me what the problem maybe
Old 10-04-2005, 11:38 AM
robertdlouhy robertdlouhy is offline
radiator
side tanks are cracked or seal is broken.or lower hose is bad.
Old 10-04-2005, 02:02 PM
chevyn0va1's Avatar
chevyn0va1 chevyn0va1 is offline
Send a message via AIM to chevyn0va1 Send a message via Yahoo to chevyn0va1
Re: radiator
rare cases a freeze plug leak
1999 Escort SE 2.0 ltr sohc, 5 speed - old one
1999 Escort SE 2.0 ltr sohc, auto - new one
2002 Dodge Grand Caravan sport 3.3, auto
located in beautiful New England.
"You know failure isn't failure If a lesson from it's learned-I guess love would not be love Without a risk of being burned" ~ Garth Brooks
Old 10-04-2005, 08:52 PM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
Radiator Drain Plug loose or broken.
Nevada Tumbleweed
Old 10-04-2005, 09:26 PM
Lynde Lynde is offline
Re: radiator
Depending on what year the Escort is, the '94 has just a gasket covering up the water jackets by the intake on the cylinder head. Then Ford got smart and changed the cylinder head design, so it's all internal in the head. It could be leaking there. However, the most common place they leak is the plastic tanks on the aluminum radiator.
