Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 10-04-2005, 10:21 AM
fuba fuba is offline
92 Marquis check engine light problem
Problem: 92 Marquis 140K miles
1- Check engine light comming on and off.
2- Hard to start, takes 4 tries, then I have to let it warm
or it won't move. Hates the cold.
3- Even at highway speeds, check engin light will pop on and off.
Where do I go from here?
Old 10-05-2005, 06:02 AM
reekor reekor is offline
Re: 92 Marquis check engine light problem
Get someone to run a scan tool on the car.
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 10-07-2005, 05:57 AM
scan tool
What kind of scan tool would I need? Is that something I can do myself?
Old 10-07-2005, 06:03 PM
Re: scan tool
A scan tool reads the computer codes, they are costly to buy, But from what I have heard on here and in other places, parts stores such as autozone will run a scan tool on your car for free.
Old 10-07-2005, 06:37 PM
Autozone only scans 1996 and newer.
Old 10-08-2005, 12:38 AM
Re: Re: 92 Marquis check engine light problem
Alright. If you have a shop manual for the car or any other ford pre 1996 it will show you how to read the codes via check engine light, only thing needed is a short jumper wire and simply count the amount of flashs to get the code #, Or you can just buy a plug with a light on it that will flash the codes for you, They are cheap most parts stores have them, I even seen them at walmart.
Old 10-08-2005, 06:50 AM
cobradude360's Avatar
cobradude360 cobradude360 is offline
Send a message via AIM to cobradude360
man let me tell u i have the same prob and ur just starting a long joruney of check engine lights but i saw at walmart that they sell a special code reader for obd1 fords only so look into that its a nice tool to have and its only like 30$
THE 92 grand marquis LS M75 with the 281 romeo v8 u cant mess with that
MODS: dynomax bullit exhaust, custom intake, polished upper plenum, 180T-stat, accel coil packs and platnum plugs
also 2005 crysler sebring sedan walter p crysler edition yea its got the 2.4 pics comin soon
Old 10-08-2005, 11:17 AM
peppermrj's Avatar
peppermrj peppermrj is offline
3145 Digital Ford Code Reader (1981 - 1995)
Old 10-08-2005, 07:15 PM
What was wrong with your Marquis?
Old 10-15-2005, 04:54 PM
Re: Re: Re: 92 Marquis check engine light problem
Any one know of a web page that explaines how to do this in detail?
Old 10-15-2005, 09:14 PM
peppermrj's Avatar
Re: Re: Re: Re: 92 Marquis check engine light problem
file:///C:/WINDOWS/Temporary%20Internet%20Files/Content.IE5/KHI7SLQB/256,1,C S (Car Science) 101
Should start on the 4th or 5th page.
Old 10-16-2005, 06:32 PM
Sorry, But this like does't work.
Old 10-16-2005, 06:38 PM
peppermrj's Avatar
http://slappy.cs.uiuc.edu/fall00/tea...esentation.ppt
Power point presentation. Try this link.
Old 10-19-2005, 07:00 AM
Re: Re: Re: Re: Re: 92 Marquis check engine light problem
Thanks for the link. One question: does the check engine light show a number, or does one have to count flashes? The link doesn't really go into this.
Old 10-19-2005, 01:03 PM
peppermrj's Avatar
Re: Re: Re: Re: Re: Re: 92 Marquis check engine light problem
You have to count the flashes.
Let us know what you find.
