Old 10-04-2005, 09:01 AM
joema joema is offline
Has platinum vs. iridium plug issue been resolved?
I've read as many threads as I could find. My 2000 has over 80,000 mi. with original plugs, and no problems. I would need a good reason to switch away from the platinums and .06 gap. Some say that GM is saying to always go with the iridiums. Others say that the iridiums are only intended for trucks that came with the iridium plugs and .04 gap from the factory. Some suggested that using the iridium plugs on trucks that came from the factory with platinum plugs may cause problems. Was there any conclusion? Is there any new info out there?
Old 10-04-2005, 09:31 AM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
Re: Has platinum vs. iridium plug issue been resolved?
GM has issued bulletins saying to use iridiums
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 10-04-2005, 09:37 AM
kenny-1907's Avatar
kenny-1907 kenny-1907 is offline
Send a message via MSN to kenny-1907
If you were to take your truck in to the dealership for a tune up you most likely would get the iridium plugs, the platnium plugs are old stock and are not being used at the dealerships or from factory anymore. They have done some research and found that using the .60 gap causes too much resistance and causes more problems than good (like i expierenced). I say use the iridium plugs and go with the .40 gap especially considering that on the package is says to NOT adjust the gap of the new plugs.
**2007 Avalanche LT. **
6" Pro Comp lift
305/55/20 BFG A/T KO'S
K&N FIPK GENII
Flo Pro V force muffler & 4" slash cut stainless tips
Color matched front and rear Bowties
3" polished stainless bull bar and Nerf bars
Old 10-04-2005, 09:52 AM
misfitt006 misfitt006 is offline
Send a message via Yahoo to misfitt006
I changed my plugs out a few months ago at 50,000 miles (not knowing that they were good until 100,000) and I was actually given a copy of the GM bulletin concerning the iridium plugs. It seems to me that they pretty much applied to every GM truck made after 1999 but don't quote me on it. And Kenny is right absolutely DO NOT adjust the gap on the plugs when you get them. Check them to make sure the gap is right and if it is wrong, don't adjust it, just take that plug back to where ever you bought them and exchange it for a new one.
