Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 10-04-2005, 07:18 AM
xjcamaro89 xjcamaro89 is offline
Cleaning MAF
How do you go about cleaning the MAF?
On a 2000 Blazer
Old 10-04-2005, 11:50 PM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
You will need to take the air intake apart so you can see the MAF. You will need the softest bristle tooth brush you can find, throttle body cleaner and some patience. Spray the throttle beady cleaner onto the MAF and lightly brush it and it should come clean. Good luck
ps if I am misleading please correct me. Thanks
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 10-05-2005, 07:08 AM
I cleaned the MAF last night before I left work and man, it was like driving a new engine! Throttle response, and shifting all inproved, maybe i will get a little better gas mileage too, thanks alot!
Old 10-05-2005, 08:06 AM
Awesome! To be honest I have never done mine. Although I should. I am just too lazy!
K&N Air Filter
Old 10-05-2005, 01:04 PM
redwheeler's Avatar
redwheeler redwheeler is offline
Re: Cleaning MAF
is the maf behind the honey comb looking thing
and yes i am a ASE Master Auto Technician
1996 chevrolet silverado 5.7L 4x4
nothin but a k&n for now i just got it
Old 10-05-2005, 01:11 PM
frehol frehol is offline
Pleeese Xplane, what is MAF???
Old 10-05-2005, 02:21 PM
The MAF is a sensor in the tube between the air filter and the throttle body, is is a square looking cast aluminum peice, that when taken out of the tube should have an open end and a end with a honeycomb grill type of peice over it. remove the 4 screws that hold the whole assembly together and you will see behind where the honeycomb was a couple of steel rods running horizontally and then a few very thin wire peices running vertically, these are the peices that get covered in a black gunk and cause problems like hessitation, rough shifting, poor idle, poor engine running all together. Take a q-tip or roll a high quality paper towel into a small point. Now your going to use some kind of cleaner, i used paint thinner, you can use rubbing alcohol, brake clean, carb and choke cleaner, and very gently rub the gunk off the horizontal steel bars and the very thin vertical wires, be very careful, if you damage any of these peices, you will have to get a new MAF. Once you have cleaned these peices reassemble and install it back into you car and take it for a ride. Depending on how much gunk was on you MAF will determine how much better performance you will notice.
Mine was really bad, when i would leave work every day i would pull out onto the road and my blazer would just about die and then would kick in and run strong till it hit the next gear, then it would feel like it would almost die again, untill the car came up to temp a little bit. it would also shift hard when you would really accellerate, and every now and then my Service Engine Soon light would come on. But i cleaned my MAF yesterday before I left work and man, mine was filthy, i had to clean it 2-3 times before I could get nice and shiny metal bars and wires in my MAF, and then I pulled out of work! Didnt miss a tick, ran like a top, ran smooth, more powerful, smoother shifts better throttle response, it was great, and it only took about 10 mins to do , so if you have any of these problems, check you MAF, it might be worth it!
Old 10-05-2005, 02:50 PM
I think I will do mine tonight!
K&N Air Filter
Old 10-06-2005, 05:33 PM
blazee's Avatar
blazee blazee is offline
Problem?
Re: Cleaning MAF
I would recommend using brake cleaner or electronics cleaner. A lot of the carb and TB cleaners will leave a residue on the sensor, and affect performance.
Old 10-06-2005, 05:57 PM
Re: Re: Cleaning MAF
Someone mentioned that to me today at my work.
K&N Air Filter
Old 10-06-2005, 10:55 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
no, dont use brake cleaner. There are chemicals in all brake cleaners that when burnt, (ie, sucked into an engine, burnt, and expelled out the exhaust), will turn into fosgene gas, and if any of you are familiar it, fosgene gas is a very fast acting nerve poison. Thats why you should never smoke while doing a brake job. You could inhale brake fluid, instantly turn it to fosgen gas, and be doing the croppy flop as quick as you can breath in. I kid you not. Please dont use brake fluid on anything that would burn or get hot.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 07-10-2007, 09:38 PM
dgoertzen dgoertzen is offline
Re: Cleaning MAF
do you know if this procedure the same for a '95 blazer?
Old 07-10-2007, 09:58 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
Re: Cleaning MAF
the 95 blazer uses a MAP sensor which is completely different from a MAF sensor but the same products mentioned about can still be used for cleaning. BTW, this thread is almost 2 years old, please refrain from posting in old threads.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Closed Thread
