Hard shifting
Ok so a couple days ago I was shifting in to reverse and it was shifting real hard like it did not want to go in to gear. so I would have to shift in to 1st and 2nd then it would go in to reverse but it was still hard. Could that be the syncros on the tranny. Oh my tranny is a M6.
Thanks
2008 G8 GT ~ 2004 Silverado LT ~ 1998 z-28
Tuned By TJ Wong - Wong's Performance Engineering ![]() |
Mine has done that a couple times. I barely let the clutch out and it will pop it or I had to go into 1st and back to R. I never thought about it too much but I haven't had any problems since then.
R.I.P. Andy...It was an honor to have known you. ![]() '01 Camaro SS - SLP Short Throw Shifter, Granatelli Air Lid, blue neon underbody kit '92 Chevy 1/2 ton 4X4 - 350 w/ 190,000 miles and in desperate need of a rebuild. '86 Chevy S10 - 350 w/ 400 Turbo trans, B&M Pro-Ratchet, 4.56 Posi, 350 is gone and slowly being replaced. |
from time to time i've had to do that with every manual tranny car i have driven... don't really think its a problem... but if it was still hard to go into maybe you could try changing the tranny fluid... i don't really know what the symptoms of bad syncros are...
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune. |
Re: Hard shifting
It has been doing it in other gears also. I had the tranny fluid changed and that helped but I heard a funny noise that sounded like the slave cylinder. It felt the same when that lil bastered 'slave cylinder' went out like 6 months ago. I am thinking it might not be ingaging all the way. Is that possible even if the clutch feels fine?
i would think that if the slave cylinder was mounted incorrectly on the transmission end (where it contacts the clutch fork) then the pedal would feel fine but it wouldn't completely disengage the clutch... or maybe something has happened to the clutch fork itself...
Re: Hard shifting
Yeah I have no clue wtf is going on. I am starting to lean towrds the slave. Oh well
