starting problems 93 dodge intrepid
I have been reading alot of threads, I have a 1993 dodge intrepid 3.3 not the es model , my problem started out while i was driving the car just stopped like it was out of fuel , i waited about 5 minutes the car started up fine, then quit after about 3 minutes,.It started again I made it home, the car wouldn't start back, the next morning the car started ans ran about 4 minutes and quite, I checked to see if it was gettin fire it was not, so i bought a coil pack,the car started up fine then quit again, so i replaced the cam sensor, It seemed to fix the problem ,so i test drove it the car ran flawless for 10-15 minutes,I shut the car off went back to start it after 1 hour the car wouldn't start back.I started reading some of the threads in this forum, I tried to unplug the crank shaft sensor ,the car didnt start, I checked the voltage on the coil pack the voltage was correct according to the haynes book.the only code i get is 12,11,55, I was getting the code 54 before i changed the camshaft sensor, One of the other things i noticed was that the cruise control light flashed along with the check engine light at one time there is no sparks coming from the coil,when i try to start the engine,also the fuel pump is working, Any help would be appreciated with this thank you.mike
Re: starting problems 93 dodge intrepid
11 is the cam sensor; I'd be willing to bet that you had a faulty cam sensor, even though you replaced it already, there are times when they come defective from the factory.
Daily Overhauls Do Get Expensive Dangerous On Days Gears Engage Dead On Day Guarantee Expires Dead Or Dying Gas Eater Department Of Defense Garbage Equipment Dodge Owners Don't Get Excited Don't Overdrive Gutless Engine Drips Oil Drops Grease Everywhere 1995 Dodge Dakota SLT 3.9 V6 1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4 |
