Old 10-03-2005, 10:40 PM
icemike89 icemike89 is offline
Wont start on first turn
I just got the car and it wouldnt start when I first turn the key.Not every time,but it did it a few times. I need to get gas,lol, but I think I might not be getting enough spark or it might need a new starter(i hope not, i just got the damn thing!)
Old 10-05-2005, 08:21 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: Wont start on first turn
you still having trouble with not starting icemike? If you r could you be more specific. Just a few questions. Is it not doing anything(ded no lights come on) or is it just not turning when the keys turned?
1999 Grand Am SS 3.4 OHV
Old 10-06-2005, 01:47 PM
Yep,except now it does it all the time. Whenever I turn the key I have to give it gas. I found out more and someone said it might have a bad idle because of the throttle position sensor might be f-d up,or might be a fuel problem.(Cant hold pressure?)Im not surewhat it is. I heard its pretty common with grandams with higher mileage.But my lights work fine.
Old 10-06-2005, 03:19 PM
Ridenour's Avatar
Ridenour Ridenour is offline
GranddAmnit
Send a message via MSN to Ridenour
I think you were right with the "can't hold pressure" thing. It sounds like you have a bad fuel pressure regulator. How many miles?
Old 10-07-2005, 10:23 PM
It has 119,000. It seems to run fine after it starts
Old 10-08-2005, 08:43 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
I agree that it sounds like a fuel pressure regulator problem. Get your hands on a fuel pressure tester (I believe Auto-Zone offers it in their free tool loan program). You should have 41-45 psi at the schrader valve key on/ engine off.
Old 10-11-2005, 09:34 PM
Gir-_-'s Avatar
Gir-_- Gir-_- is offline
Send a message via AIM to Gir-_-
I have this same problem..
I am new to the forums *never posted, just reads*
Umm.. car info.
99' grand am se
around 148k miles? *I know -_- lots* Runs Great *thumbs up*
Anyways, yea... it idles around 650 in park no AC
I figured it was my driveway being slightly a ramp (ie. no fuel to be where it exactly needs to be) but I've noticed the problem elsewhere, 3 tries recently *untill I gas'd it* it wouldnt start
04' Mazdaspeed Miata - GT2860 @ 10psi
99' GRAND AM SE V6H.O. 188whp - Sold
Old 10-11-2005, 09:43 PM
Mr. Luos's Avatar
Mr. Luos Mr. Luos is offline
Firebird Guy
I was having some rough starting issues with my 2001 GT.
Changed the plugs from some cheapys to ACDelco's. Problem solved.
Bad spark can easily cause starting issues.
But like mentioned above, don't rule out fueling.
1999 Pontiac Trans Am WS.6 #1747
Stock'ish'
Old 10-11-2005, 09:49 PM
Gir-_-'s Avatar
Re: Re: Wont start on first turn
I see...
I've been meaning to get the plugs/wires replaced, just havent had the money... Soon though.
Old 10-11-2005, 11:44 PM
I just got new plugs-Bosch platinums
Old 10-12-2005, 08:17 AM
Gir-_-'s Avatar
Fix?
Old 10-12-2005, 04:52 PM
No the plugs didnt solve it, but it seems to be running a little better.
Old 10-12-2005, 05:36 PM
Mr. Luos's Avatar
Firebird Guy
You got the wrong plugs.
I had the Bosch....ran like crap. Wouldn't start all the time.
Went back to the Delco stockers. Much better.
Stock'ish'
Old 10-12-2005, 08:28 PM
I def. like the bosch better than the others.Its not the plugs causing the problem,it's been doing this before I got new plugs.
Old 10-12-2005, 08:48 PM
bosh plugs work great for 10-20k miles. then the electrode starts to fall (probley exsessive heat), making the gap smaller, making it run like shit.
On a carb motor they(bosh) seem to be fine, but not with MFI. From what I've seen anyway. My 76' 442 has them, starts perfect. Had some in my 99' GA and they fouled out with in a couple months and changing the plugs twice with in months sucks!
But if the new plugs dont make it start right off hav the fuel pressure checked . Get the TPS checked out, it maybe on the fritz, but no car will always start right up first click every time.
