Old 10-03-2005, 10:12 PM
Hickory1973 Hickory1973 is offline
Unhappy Wont start Mystery ???????
When i try to start my truck all i get is a clicking noise at the starter. This tells me that my ignition switch is ok cause its sending fire. I had my starter tested and they said it was fine. I tried replacing the battery and didnt help. I replaced the Neutral Safety Switch and it started and ran for about a week (during that week it still had problems starting periodicly). Now it is broke down again at my home with the same problem. I checked the battery cables and starter wires and they seem fine. One cable is kinda stripped where it screws into the battery (side mount post) but it stays in fine and sends juice to the whole truck ie: lights, dash, etc. I dont understand whats going on. It has me stumped. Please any assistance or advice would be GREATLY appreciated ???
Old 10-03-2005, 11:19 PM
kenny-1907's Avatar
kenny-1907 kenny-1907 is offline
Send a message via MSN to kenny-1907
Re: Wont start Mystery ???????
well considering the ammount of details about your ride that you left out , it could be many things. Dirty/loose connection, bad solenoid. I am kinda leaning to a bad connections considering you said that one post is kinda stripped a bit. It may be getting emough of a connection for the lights to work ect but not enough when the load is applied to try and start.
**2007 Avalanche LT. **
6" Pro Comp lift
305/55/20 BFG A/T KO'S
K&N FIPK GENII
Flo Pro V force muffler & 4" slash cut stainless tips
Color matched front and rear Bowties
3" polished stainless bull bar and Nerf bars
Old 10-04-2005, 08:31 AM
Lobstah Lobstah is offline
Clicking is usually a sure sign of low voltage going to the starter.
I had a problem like that on my son's truck. I started with a meter on the battery posts, 12v. Went from the negative post to the starter solenoid, 8.5V. This was through what appeared to be a fairly new cable, 2ft long. Checked the posts again, 12v. Checked from the negative post to the CONNECTOR on the pos side, 8.5v. The battery connector on the cable was actually cracked, so was dropping almost 4volts from the post to the cable. Really strange problem, but was glad to find it.
Lob
2005 2500HD 4X4 Ext cab, long bed
2001 Lincoln Continental
1969 Camaro SS (yeah...it's real)
Old 10-07-2005, 08:24 PM
Smile
I dont get it. I took your advice and replaced the starter and didnt turn over. I checked the voltage at battery and got 12v but got 9 volts at starter end of cable so i replaced the cable. The truck started and i drove it to the store a mile away. When i came out it wouldnt start but it at least turned. The engine kept turning but i want getting any fuel to the throttle body. Sometimes the fuel pump kicks on when you turn the key and sometimes it doesnt ?????
Is something happening in my truck im not seeing? Owned for almost two years without a problem. Now the spark plug wires, the starter, the fuel pump all go out within a week ??? Power surge causing it maybe?
LOL ........ truck would make a nice bonfire. Anyone have a match!!!
Old 10-08-2005, 03:09 PM
kenny-1907's Avatar
........... I did not see anyone give you advice to change the starter and you are still leaving out a ton of info that can be useful. What year is your truck for one. It could be the fuel pump going out depending on the year, it culd be the ignition module starting to act up, could be bad cables........you need to provide more details.
6" Pro Comp lift
K&N FIPK GENII
Old 10-08-2005, 03:16 PM
"I checked the voltage at battery and got 12v but got 9 volts at starter end of cable so i replaced the cable."
That's definetly a problem. Did you really scrape the posts before you put the new cable on? Did you recheck the voltage at the starter to make sure it's getting 12V now?
It sounds like you've got a bad/corroded connection either on the battery posts, or on the ground cable running to the frame. Take a wire brush to all of them, squirt them with WD40, and tighten everything down.
Lob
Old 10-08-2005, 03:32 PM
Juiced383's Avatar
Juiced383 Juiced383 is offline
Re: Re: Wont start Mystery ???????
Lob
That's exactly what I was thinking
Old 10-08-2005, 05:11 PM
Dont get me wrong im not blaming anyone at all for bad advice or nothing. I took the advice i was given and made the choice myself to change the starter which turned out to be the correct problem. I was just wondering if anyone knew anything about power surges or something of that nature that might be making all these parts go bad in such a short period of time.
My battery and cables are all new now and i have that problem fixed. The battery isnt the problem now. The starter turns the engine over fine now but im not getting any fuel. The fuel pump kicks on sometimes and sometimes it doesnt. I just cant figure out why so many electrical components are going bad all within a week. Cables, starter, fuel pump ........ all in 6 days and havent had a problem with the truck before.
93 Silverado
4.3 v-6
Old 10-09-2005, 12:26 AM
kenny-1907's Avatar
well you are also in the wrong forum , this is for 99 and up nbs. Either it is the fuel pump porking out or the ignition module. The ignition module is easy to remove and have tested, it coltrols the spark and fuel.
6" Pro Comp lift
K&N FIPK GENII
Old 10-09-2005, 07:17 AM
Lol didnt think about the ignition module. I guess as soon as i find it ill go have it checked lol. Thanks for the tip.
Also i didnt post in this forum, i posted in another forum and when i went back to check my post the next day the admin left me a message on that forum saying my post had been moved to this one. Not sure why but probably because i didnt note the year of my truck in my original post. Sorry about that.
Old 10-09-2005, 12:12 PM
kenny-1907's Avatar
The ignition module is located under the distrubuter cap and rotoe and looks like this: it is a matter if just unplugging the plugs and removing the two screws.
6" Pro Comp lift
K&N FIPK GENII
Old 10-09-2005, 01:13 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
I had an old v6 Celebrity that would not start... Changed the module, and no more problems... except that I still had an old Celebrity
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
