Old 10-03-2005, 09:42 PM
djd99's Avatar
djd99 djd99 is offline
Help Ignition/Electrical problem
Howdy I have a 96 with a 2.2 that just died going down the highway. It did throw a camshaft position sensor code before it Passed. Ever since then It will crank but not even attemp to fire although it did cough once. I sprayed starting fluid in it and still didn't attemp to fire so I guess I rulled out a gas issue. I check the spark and found a red weak spark. So for giggles I had a extra camshaft sensor laying around and swapped them out and still cranks but does not even attemp to fire. Does anyone no where or what I should attemp to do next. Shouldn't the spark be blue?
2000 S10Blazer LT 4 Door 4x4
Billet Grille insert
Winter 30X9.5QR15 BFG's All-Terrain T/A KO's
Old 10-04-2005, 09:24 AM
Lvtrucks2000 Lvtrucks2000 is offline
Coil packs or ignition module behind the Coils packs.
Old 10-05-2005, 08:10 AM
djd99's Avatar
Hi I'm assuming it's not one of the coil packs due to all 4 plugs have the same type of spark. However the ignition module could be it but I thought they either would work or not. Any other ideas before I start replacing expensive components?
Old 10-07-2005, 09:42 AM
graymarki graymarki is offline
Crankshaft Position Sensor
You need a crankshaft position sensor. When it becomes defective, as they do on these cavaliers, they don't send a signal to the coil pack, therefore the weak spark, so you automatically suspect the coils. You also will not receive a code when these are defective. You can buy one from Advanceautoparts for about $62.00, that should solve your starting problems.
graymarki
