shaking steering wheel at low speeds
ok my car has power steering. the fluid level is ok. only honda p/s fluid is always used. new rotors and brakes were recently replaced. only the steering wheel shakes. not the car, body, or suspension. the steering wheel shakes (turns clockwise, counterclockwise not side to side) about 1/2 an inch at speeds from 10 to 35mph. on the freeway it's ok.
is this a rebalance tire issue? or an alignment issue? i'm on stock springs and struts. |
I would have to go with telling u to have your tires balanced and your car aligned. That should solve ur problem.
°Sä®GëNTö69° B20B POWERED '91CRX SI
Re: shaking steering wheel at low speeds
Tire balance problems usually don't show up until 60mph+. Alignment issues won't cause a steering wheel to shimmy. My guess is that you have a bad tire.
bad tire or bent rim is my guess, hopefully its not a loose rim. My buddy had that problem once, when he would go from a stop he would hear a clunk, and the same from rolling and stopping. we checked and all his lugs were loose, that would have sucked if we didnt catch it soon enough.
The Evil Sleeper
Sounds like one of your belts let loose in your tire.
Re: Re: shaking steering wheel at low speeds
I would have to go with what this man said. I had the same problem. I took my car to walmart, which said they couldn't blance this one wheel. Replaced the wheel, and problem when away. Try getting your tires balanced and listen to what they say.
Tien SS coilovers Ingalls Alignment Kit Fluidyne HalfSize Rad AEM CAI AEM Fuel Rail AEM FPR **In the works** New Garrett T3/T04E .63 A/R Tial 38mm Wg Tial 50mm BOV Fixing the shit job the body shop did to my wrecked car. |
Re: Re: Re: shaking steering wheel at low speeds
**Edit** When I say wheel I mean rim. When I say tire (which I don't in this case) I mean tire.
Re: Re: Re: Re: shaking steering wheel at low speeds
so i found out today i need new tires. after 44k miles a tire goes bad. they're 65k tires. basically i had bf goodrich tires that had a bubble on the tread an that part was about to wear out. they could replace all 4 with warranty and give me $65 credit plus free installation ($36 value new valve stems and unlimited rebalance included).
point is.. they only have dunlop 65k mile tires. are they good? 480 traction a and wear b? i think or something like that. it's the same numbers/letters as the bf goodrich ones i had before. these cost $36 per tire for dunlop (bfgoodrich originally cost $40) so 144 for all 4 tires minus $65 credit and free installation plus tax would be about $91. is that a good deal for dunlop? my dad wants me to get michelin.. but they don't have michelin for my 13 inch steelies |
jackassi, how the hell did you get your name changed and still keep your post count and everything????
Saturn Stealership Technician #331 |
![]() Quote:
$91 for 4 new tires is great deal if you ask me and they aren't even no name knock-off tires. I'd rather have Dunlops than BFG's. Michelin tires are the best street tires but after their ridiculous performance at the USGP I stay away & don't support their business. This is what I say about Michelin . . . . . Quote:
I had one of the admin's LadyNRedSi introduced me to change it.
Dunlops are good tires. I think I have a similar issue. I have cheap Warrior tires. It's raining today and I was hydroplaning like crazy. I have unlimited balancing though so I'm going to have them checked out.
2008 KIA Spectra5 SX 2010 Honda CR-V EX |
