Oil leak and oil pressure high
my car has just started to leak oil its not a fast leak btu i cant find where it's coming from what the easyest way to find an oil leak and since the leak my oil pressure has been run real high like up in the 80 as soon as i start the car it goes right to 80 but if i let the car set it drop down but as soon as i hit the gas it goes up just like the gas gage i cant figure out why it doing that
thank for your help |
is it the LT!? If so check your optispark seals. they tend to go quite often.
how do i no if it is a lt1
i have the LS1 and mine does the same thing.
when i first start the car the oil pressure is around 70-75 psi, but eventually it goes back to 40psi. i think the oil just has to warm up and "loosen up".
If you have the means and the desire, be prepared to do whatever it takes!
Re: Oil leak and oil pressure high
but mines doesnt ever go down the only time it goes down is when im idling but as soon as i go it shoots right back up |
at idle mine also returns to 40psi.
but when accelerating it goes up tp 60-65psi. thats just because the motor is working and the oil pump is working harder. i think that as long as it stays above the red line its ok.
as your engine gets warmer the oil pressure will go down its so high when u start if because the oil is cold and thick what weight oil do u have in it?
i use 10w-30 because its summer.
the only thing is 95firebird doesn't know where the leak is. i lost 2 quarts of oil once. cause= stupidity. i forgot to put the dipstick all the way down.
im using 10w-30 i drive the car back and forth to work on weekend for abotu 2 hours there and 2 hours back the whole way there the car runs a about 75-80 psi
try reaching over the engine and under the windshield and feel around and see if u get oil on ur hand
i have a leak in that spot and was told $400 to fix so i left it as it is a very slow leak. and by the way ur gas gauge going up when u take off is normal. its due to the gas getting sloshed to the back of the tank which makes the guage go up ull probly notice ur gas drops when u stop hard as well its normal |
- Jason 1995 Pontiac Firebird ![]() ![]() User Guidelines | VB Codes Explained | AF Merchandise "Each of us, is in the scheme of things, insignificant. But millions of insignificant people, doing a tiny bit, can add up to be a very significant force." |
Re: Re: Oil leak and oil pressure high
those small engines are supposed to run around that psi.
as to why it just started happening,
Well the guy at autozone is completely wrong. If you read your oil fill tube cap, then you will see that in the center is says to use SAE 5W-30. I don't see how using 10W-30 would be benefitiary on a high mileage car. Especially since they make specially formulated versions of 5W-30 for high mileage vehicles.
My oil pressure, when I first crank it, it raises to 80 psi. But it eventually falls back down to about 55-65. If your oil pressure is at least falling back down to around that area psi, then there's no problem. The 3.4's are supposed to run between 50-65 psi. And if you say that once you start it up and go driving, that the oil pressure doesn't drop any further... then I would recommend that first, you started to use 5W-30 oil, and then add a can of Seafoam into your engine (same place where you would add your oil). That should help clean out the internals of your engine. After about 500-750 miles, I would then drain your oil and add new oil. That way you can get all the crud out of your engine that Seafoam has loosened up.
thank again every one |
