okay.. I had just gotten my windows tinted (looks sweet btw)
and I was driving back home. The car started normally and there was no problem there. I start driving down the street for a couple of block and then I'm stopped at a red light. I was pressing the brake and out of nowhere the car just lunged forward just went vroom on its own for a little bit and the car went forward. Good thing I was stepping on the brake pretty hard. I was like WTF cause it just gave gas to itself I guess. Then, I passed by my friends house who lives on that same block and I was waiting for him to come out and I was stopped infront of his house on [D] with the brake pressed and vroom again.. the car lunges forward and then dies. It takes me a couple of cranks to start it back up and the whole way back home I had to put the car on neutral and control the RPM's with the gas pedal cause if i let it go, the car would get too low and eventually die. It wouldnt automatically fall to 0 and die but it stay at around 500 for a little bit and just fall. I drove it today and realized it doesnt do it when its cold. What could be wrong?
1990 IROC-Z 5.7 TPI (1 out of 4,213 IROC's made in 1990) Only mod is magnaflow 3" cat back and K&N filters... im broke.
Re: weird idle at stoplights
could be throttle position sensor, or maybe some vacuum problem???
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later. 194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies 179.75 RWHP, 204.52 RWTQ ON ITS WAY: MORE R.I.P. Andy 87 Benz 190e - DD 01 EX250 - still gotta get my license for this thing |
Hm, maybe it can be your Ignition Control Module. That or your throttle position sensor, if you want you can CHECK to see if your Ignition Control Module, by taking it to Autozone or Orielly Auto Paets if you got them there, for free too. If its not the ICM then im stumped.
throttle position sensor (tps) or idle air control (iac)
try scanning for codes... and replacing one or both of those...
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune. |
ahh nice drvng, i was trying to think of IAC but couldnt remember the name
KISS, spark plugs , plug wires, ignition cap, good gas, fuel filter, fuel pump
Re: Re: weird idle at stoplights
okay.. did the paper-clip check thing and got code 12 on and on and on over like 10 times so there are no other codes and I know code 12 is normal.
A car needs to be tuned every 3 months or 30K miles.. which ever comes first..
his problem is not a tune, i already said that... he has a sensor problem.
und funny to anyone?
91 RS Camaro V8 305 TBI cold/ram 14"/3" open element K/N filter 3.73's B&M Megashifter 180 thermostat Flowtech TERMINATOR Exhaust 3" exhaust cutout Silvania Silverstar Headlights Ronal R15 Firehawk Wheels Hankook Ventus Sport (front) Sumitomo HTR+ (rear) 275/40ZR 17 all around... _____________________________ |
lol i didn't read it... anyone here drive 10000 miles a month? LOL
3 months or 3000 i think its supposed to be... i service mine every 2500, actually 5000 now that i run synthetic...
oil change is every 3k miles, not a full tuneup... you crazy?
OK im gonan replace my plugs and wires every 3k :/ and 10000, thats what I average per year LOL
