Old 10-03-2005, 02:53 PM
dirtybird78 dirtybird78 is offline
blinker issue please help
my friend has a 94 grand am and when you hit the right blinker it would just stay solid and not blink. the left one would and the hazzards worked. she came over today and i was going to replace the turn signal switch but now left and right are doing the samething (staying soild) any help wold be greatfull
Old 10-05-2005, 12:00 AM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: blinker issue please help
a burnt out bulb or the blinker/flasher part is defective. I do not know for sure where it is located though.
1999 Grand Am SS 3.4 OHV
Old 10-05-2005, 02:49 PM
Ridenour's Avatar
Ridenour Ridenour is offline
GranddAmnit
Send a message via MSN to Ridenour
If it is actually the blinker 'module' (multi-function switch) then it may have, in fact, become dirty and need cleaning or replacing. It's located in the steering collumn at the base of the turn signal lever.
Old 10-05-2005, 03:34 PM
gmack221's Avatar
gmack221 gmack221 is offline
If you turn on the 4-ways and all the bulbs work then I would start with the turn signal flasher unit. Its under the dash, left side of the steering column, there is a small door you can pull down, mine fell right out when I opened the door. (the flasher unit/relay should be about $5-$10 and is the part that makes a clicking noise when the signal is on) My 95 grand am had 2 flasher units (one for the 4-ways, one for the turn signals) and they should be next to each other, so get one to make noise then follow the noise (takes 5 mins to find and 30 seconds to change). Start with the flasher unit, the column switch is about $80, use this as your last option.
Old 10-07-2005, 12:58 PM
ok so the right was solid and the left blinked, she came ove and they were both solid(not blinking any more) so replaced the turn signal switch it was still the same. checked the front bubs and the looked good. after i put the bulbs back the right one started to flash. so i tried messing with the left one and i still cant seem to get it to work. think i am going to shoot this car.
Old 10-07-2005, 03:11 PM
gmack221's Avatar
when my turn signal relay (flasher unit) went it would flash a couple times then stick, try switching the 4-way relay & the turn signal relay, or turn on the 4-ways and see which one doesn't light up, if they all light up its almost got to be your relay, since you already changed the switch.
Old 10-14-2005, 09:46 PM
found it a couple of days ago. just thought id post so if somebody has the same problem. the right front blinker fix was the front bulb wasnt a good contact. cleaned and fixed. the left was the rear same sit. hope that helps if anybody needs it
Old 10-15-2005, 01:59 PM
i thought i had mention'd that.
