Bronco II Cold Air Intake???
I've been looking for a cold air intake for a 1990 2.9L 4wd Bronco II, I can't find one that will fit so i was wandering if any one has any suggestions on what i could get. Any comments are welcome.
Thanks |
Only thing I could find was a couple of different drop in filters from K@N, Airraid, and Holley. You can find them on www.truckperformance.com they also have a couple other parts on there for the bronco II like headers by JBA and pacesetter. Jet chips make a power module also on the site.
Is there anyway to put on a cold air intake from another car, like another model? or is that even possible?
Thanks for any help |
not sure. sorry
Re: Bronco II Cold Air Intake???
You might want to read this test on air filters.
home.usadatanet.net/~jbplock/ISO5011/SPICER.htm MT-2500 |
does you b2 have a mass air flow sensor if not you can make a cold air intake you just need to get a peice of alumminum as big as your stock air box tube a filter and a coupler to atach the pipe to the tb it will work i had a 87 b2 and had it bored out .60 i had looked for performance parts like a big cam bigger injectors hedders but could never find anything dam german motor
Actually they have full kits. You also could just get a filter with a spectre with a 3 inch opening for only 20 bucks at a autozone. But If you desire a full tube and everything use one from a 96 dodge neon. They have very cheap ones on ebay for 30. Just make sure to get the ones that do not have the 90degree elbow welded because they will not be needed. Hope this helped.
