Old 10-03-2005, 02:28 PM
holyniht holyniht is offline
yet another camber question
i took my lowered civic to the sears autocenter in hopes of getting an alignment due to tire wear. The guy told me that my camber was way off and that an alignment wouldnt fix the tire wear issue. i frequent the board alot so i figured that i would need a camber kit. i mentioned this to him and he said for my model i should get adjustable ball joints. Which one should it be a camber kit or the ball joints?
Old 10-03-2005, 11:24 PM
BullShifter's Avatar
Re: yet another camber question
How much is the car lowered?
Old 10-04-2005, 07:43 AM
snowman2005's Avatar
snowman2005 snowman2005 is offline
Send a message via AIM to snowman2005
did he at least put ur toe in spec?
ive got manuals
92-95 civic 96-98 Civic
clicky here clicky here
WTB:92-95 EX/SI cluster w/tach
FS:*NEW* 92-95 civic coupe black floor mats(4). pm me for pics or offers
Old 10-04-2005, 04:32 PM
KrisSmithRocks's Avatar
KrisSmithRocks KrisSmithRocks is offline
Send a message via AIM to KrisSmithRocks
I think what he meant is that the alignment wouldn't fix the tire wear until you get a camber kit of some sort. The adjustable ball joints are nice but there is another option that relocates the upper control arm on eccentrics so you can adjust the front of and rear of the control arm independantly. and speaking as an alignment tech i would far rather adjust one with that style then the ball joint style, there is more flexability. just my 2 cents.
89 Honda Accord LXi 2dr- Daily driver SOLD (sniff sniff)
89 ED CRV... soon to come GSR head, ARP studs top and bottom, T3/T4 at about 6psi ... it's quick...
89 ED DOHC ZC
Old 10-04-2005, 08:33 PM
i cant tell u xactly how much i lowered it since my struts were saggin b4 i went coilover. but its lowered just above the rubber of the tires. he didnt put the toe in spec, said he wouldnt touch it since the camber was so bad. and by the looks of the tire i changed my camber must be really bad.
Old 10-04-2005, 10:19 PM
Re: Re: yet another camber question
Struts don't regulate height even when they are worn, it's all in the springs. I agree with Kris, espeically since it sounds like it's lower than 1.75".
Lowering a car on bad struts isn't a good idea. You should upgrade the struts & have camber kits installed, IMO.
Old 10-05-2005, 05:55 AM
im not running on stock struts, i swapped everything out, for some performance struts and a coilover spring set up. they were sagging b4 and my ride was rough which led me to just swap everything out.
Old 10-06-2005, 12:16 AM
Ok, misunderstanding.
Old 10-07-2005, 10:03 AM
i decided to go with the skunk 2 front cambers, should be in by tuesday. they look pretty simple 2 install. The guy at Sears my front lower control arm was loose and i need knew wheel bearings. If any body has had it done, about how much does getting new wheel barrings run?
