Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 10-03-2005, 01:36 PM
GTPWarrior88 GTPWarrior88 is offline
Emergency Brake
When I started my 95 GTP in the morning, the emergency brake light was on when the emergency brake was up. I pressed it up and down a few times to see if it was stuck but the light was still on. I drove around for a little and then it finally went off. Do you know what the cause could be? Thanks!
Old 10-04-2005, 09:18 PM
KX2000GTP KX2000GTP is offline
Re: Emergency Brake
Was it the emergency brake light, or just the brake light? If it was the brake light, check your fluid. if the fluid is low it will give you a brake light and sometimes driving around makes it fluctuate therefore making the light go off. I had the same problem on my '95 bonneville that's why I suggest this.
Good luck.
Old 10-04-2005, 09:19 PM
Re: Emergency Brake
as a side note, if you fluid is low, check yer brakes. When the brakes get worn it causes the calipers to expand, therefore using more fluid, which could be the reason for the light.
Old 10-05-2005, 11:55 AM
I will check my fluid. Thanks for the reply.
Old 10-07-2005, 01:35 PM
Re: Emergency Brake
Did you ever figure out the problem?
Old 10-12-2005, 01:44 PM
I checked the fluid and it seems alright. I need to check the brake pads and the rotors. Ill let ya know how it turns out. The light still is occuring..on and off when I drive.
Old 02-15-2007, 09:48 PM
krack86 krack86 is offline
Exclamation Re: Emergency Brake
i was fixing my exaust on my 95 grand prix and i put it on ramps. i engaged the emergency brake. when i was finish i released the brake but it seemed like it wasnt full disengaged. i could feel a difference driving between brake on and off but it still seemed like it wasnt fully off. there was quite a bit of resistance.
Closed Thread
