Originally Posted by Greg5150
Does anyone have experience replacing a pressure control solenoid on a 1997 PA? I understand the trans side cover has to be removed and the engine cradle has to lowered to do this. How far must the cradle be lowered? How difficult is the job? Thanks
Haven't done a PA, but have done a Saturn L... hoping yours is easier since your V6 engine should be one cylinder narrower than my L4 is and your vehicle should be wider. All the stuff above the trans on mine had to come off, which included battery, battery support, coolant reservoir, fuse box, range sensor. Also removed wheel, fender, strut to steering knuckle bolts, pulled drive axle from trans (had enough room that I didn't have to unbolt it from hub), drained trans oil (of course), removed transmission to frame mount, and then lowered engine+trans enough so that side cover could be pulled away enough to reach a hand into where the PCS was. All in all, it was about 6 hours and a major pain... looked like I threw a grenade under my hood with all the parts lying around. Anyhow, I work for a solenoid manufacturer and we're developing an aftermarket replacement for the troubled Delphi PCS that the 4T40/45/65E transmissions had for original equipment... the prototype I put in my car cured all the problems I had, which included harsh shifts, shuddering, and occasional bucking after shifts. Best of luck.
