95 metro no power
I have a 95 geo metro 1.3 auto with 106000 miles on it.
it runs fine at idle but no power when trying to accelerate... Fuel pressure is at 22 psi - is that right for tbi exhaust appears not to be blocked Has spark just replaced t/b to see if that made a difference - nope plugs and wires replaced when i did the head 10,000 miles ago |
Re: 95 metro no power
might run a compression test and make sure everything is ok, should be 170psi or higher on each cylinder when warmed up. does it miss when you step on gas or backfire or just bogs down? its possible pressure is right on fuel but volume is to low, might replace gas filter and check fuel flow. have you checkd timing to make sure it is right. did this happen all at once or just slowly got worse?
Re: Re: 95 metro no power
it just bogs down just replaced the fuel filter for the 2nd time in 2 weeks timing is right on and it slowly got worse |
adjust your clutch or your clutch may be slipping
did replacing filter 2nd time help at all?
