I have a 98 Blazer LT with the computer climate control. Recently the climate control stopped working and nothing comes on. Not the light for the AC, blower fan doesnt spin, vent doors dont open and close, pushing any putton on the climate control does nothing. At night only half the night lights on the climate control comes on. I was planning to get a new climate control but I was wondering if there was possibly another fuse or relay besides the ones in the drivers side engine compartment and drivers side on the dasdoard between the dash and door. I figured at least some power is coming to the climate control because some of the night lights come on. Can any one suggest something to check before replacing the computer climate control.
98 Blazer LT 154,000 miles Drives like a gem Approx 18 mpg Current mods 7 " monitor in passenger headrest, working on drivers Cassette player replaced with DVD, audio not connected yet Lots of detailed pics coming soon |
SO I had half your problem. The lights on some of the controls on my 98 with the climate control went out. I thought damn a bulb went out back there or worse theres are breaking! So I went SHIT and kind of dope slapped the thing, wouldn't you know it the lights came back on! I am sorry ic ould not help further but I believe your issue may be a loose connection. I am sure someone on here will come up with a much better answer for you. Good luck and please let us know how you made out!
2002 Pontiac Gram Am K&N Air Filter Mobil1 5W-30 Extended 15K 2 JL Audio 12" Subs Sealed JL Audio Box Coustic 400 Watt Class D Mono Amp Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner Polk DB750 6.5" all around Yankees Suck!!!!!!!! |
Re: Computer Climate Control on 98 doesnt work
still no help? is there some way i can check the blower to make sure it is working without cutting the box open so I can at least isolate that as the problem. ichecked all the fuses in the 2 fuse panels but is there another that controls the blower? where would be a good place to get the computer climate control?
1)Does the radio work? If so, one of the fuses is OK
2)I assume you've checked the HVAC Fuse 1, right? 3)Remove the HVAC control unit. Use a volt meter and measure voltage between ground, and terminal C12 with the key in the RUN position. It will be an orange wire. You should see battery voltage there. 4)Use a volt meter and measure voltage between ground, and terminal C6 with the key in the RUN position. It will be a brown wire. You should see battery voltage there. 5)Use a volt meter and measure voltage between terminal C10 and C12. You should see battery voltage there. Post back with the results or questions. |
Re: Re: Computer Climate Control on 98 doesnt work
Re: Re: Re: Computer Climate Control on 98 doesnt work
You might consider hitting a local boneyard or www.car-part.com for a used module. Or get the part num from the dealer for the HVAC computer and buy it from www.gmpartsdirect.com.
![]() ![]() 95 s10 Blazer, EGR Mod, ZQ8 Steering box mod, 99 Center console shifter mod and more... See everything at www.pghconsulting.net/teal |
Dealer wanted to sell it for $380 got it at the junkyard for $50. It is a little different with the knobs but works perfectly. This was out of a Bravada, didnt know they were the same. Now I finally have heat I feel a whole lot better.
