Go Back   Automotive Forums Car Chat > Honda > Prelude
View Poll Results: prelude revs up and down???
hmmm 0 0%
hmmm 0 0%
Voters: 0. You may not vote on this poll
Old 10-03-2005, 02:36 AM
babyphay babyphay is offline
92 prelude problems
Hey wassup? Having problems with 92 honda prelude si........It revs up and down when in neutral??????And wondering which transmissions would work with mine????haha has no reverse....92 prelude si h23 5 speed
Old 10-04-2005, 08:53 PM
honda_racing101's Avatar
honda_racing101 honda_racing101 is offline
Send a message via AIM to honda_racing101 Send a message via MSN to honda_racing101 Send a message via Yahoo to honda_racing101
Re: 92 prelude problems
What is the point of your poll?
As far as transmissions that work.-h22 and h23
dSoc member #67
1995 Honda del Sol EG2 VTEC Milano Red. RIP :crook:
1994 Honda del Sol EG1 S-full VTEC conversion.
Buy my Del Sol parts!!
Old 10-04-2005, 10:27 PM
AllmotorBB6 AllmotorBB6 is offline
Re: Re: 92 prelude problems
and f22 i believe. We need more info other than just that its jumping around at idle. Do you ahve any check engine lights? Check your iacv and make sure the screen isnt clogged up. You could have a vaccum leak as well as many other things which cause the idle to jump around.
Old 10-19-2005, 10:44 PM
sgauss sgauss is offline
I have a h23 in an accord 91 body and when it is over 90 degrees F outside and I am at a light it revs up (1250) and down (750) if I am in stop and go traffic (dang college town). Would this be the same thing maybe?
Old 10-20-2005, 11:01 PM
lilwhitelude lilwhitelude is offline
Send a message via AIM to lilwhitelude
Check idle air control (IAC) and coolant temperature sensor (CTS). If the temp sensor is reading too cold excess fuel will be sprayed, therefore high idle. O2 sensor reads rich mixture and then tells computer to not spray so much fuel, leading to low idle. Which will result in surging. Which is exactly what you are describing.
Have someone put a diagnostic Scanner (not a code reader) on it and read the output of the sensors. The check enging light may not come on unless these sensors are reading out of range.(negative voltage or excessive voltage). If your engine is obviously warmed up and the scanner says your engine temp is 32 degrees, that would be your problem. Or if it shows excessively less than normal temperature.
Also check the air intake temperature (AIT). this can cause similar problems if not working properly. And of course the obvious vacuum leaks.
The most important part is to find someone with a proffesional enhanced scanner.
