Old 10-03-2005, 01:42 AM
Joshua Cox Joshua Cox is offline
Lightbulb electrical problem
Have a 1996 Cherokee with 65,000 miles. Engine just started running rough, but I think it's an electrical problem. First time started this morning very rough. Then tried to start it at around noon, and it would not even crank...after a couple try's, it started. Then tonight, it would crank, but the engine would not fire worth a darn. Help, please....
Old 10-03-2005, 07:48 AM
89ltd 89ltd is offline
Re: electrical problem
check for spark or spray some starter fluid down the throttle body to see if it fires.
Old 10-22-2005, 08:19 PM
pacificbob pacificbob is offline
[quote=pacificbob]I also have a 1996 with kinda the same problem. By mistake I opened up the bus fuses in the engine compartment (passenger side. and found a sticky relay to the fuel pump. gave it a light tap and been running fine since.
But I now havea problem my brake lights. got is down to the switch but haveno idea how to trace out the wires. any suggestions would be appreciated.[quote]
