Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 10-03-2005, 12:34 AM
fordin K fordin K is offline
fan control module test ?
Hi was wondering how can you test the fan control module and verify it is bad ? what kind of tests and specs am I suppose to perform. I know most of the time the a/c compressor doesn't kick on, the idle up does not function and the cooling fans don't come on like suppose to, but what kind of readings should I get out of the module ?? any help would be much appreciated.. thanks
Old 10-03-2005, 09:52 PM
airic airic is offline
Re: fan control module test ?
That is real easy. If you swap in a good one, and it works it was bad.
If not troubleshoot the wiring attached to it for the expected signals.
Old 10-06-2005, 07:20 PM
I did swap in a new one and it did work. but I want specfic values. its a nice $185 guess each time if not
