Go Back   Automotive Forums Car Chat > Volkswagen > Passat > '97+
Old 10-03-2005, 12:30 AM
fordin K fordin K is offline
abs module test ?
Hi just wondering what kind of tests can be performed to verify the abs
control module IS the culprit. I've read alot of posts on how the "ABS"
light stays on and the "Red Brake light" blinks but brakes work ok. and turns out the module is bad. My question is how can you tell ? what kind of readings am I looking for to make a technical verification ? any help would be very much appreciated..... thanks
Old 10-06-2005, 10:00 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
try wiggling the connector and see if it clicks or the light goes out
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 10-11-2005, 10:04 AM
Stormur Stormur is offline
Re: abs module test ?
Where is this cable. I am also having this problem with my ABS. It aslo started with the Tach stoping while i was driving.
Thanks for the help.
Old 10-14-2005, 10:53 PM
VDUBMAN
The abs module is right next to the washer fluid resivour fill. Convienently located so that after years of adding washer fluid and it spilling onto the module it mysteriously shorts out and stops working?????!!!!!!?????!!!??!?!?!?!
