Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 10-02-2005, 11:40 PM
rhodey60 rhodey60 is offline
truck
1990 4x4 leaky rear end
Old 10-03-2005, 02:17 PM
ECVcrawltoy711 ECVcrawltoy711 is offline
Re: truck
so where is it leaking from. drain hole fill hole a black hole
Drew
Old 10-04-2005, 01:36 AM
Re: Re: truck
Drew
i ffound out today that there is ahole in the housing im wandering if jb weld would fix the leak
Old 10-04-2005, 01:49 AM
Re: Re: truck
Drew
the housing has a pin ho how can i fix this leak
Old 10-04-2005, 08:36 AM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Try JB Weld. If it works let us know.
If it doesn't, have some one hit it with a welder, should seal up.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 10-07-2005, 12:47 AM
Re: truck
where is it at. ii would use a real welder but JB weld will work Make sure it is clean tho before u put it on
Drew
