Old 10-02-2005, 11:09 PM
91crxracer 91crxracer is offline
better to boost a d16y8 or zc?
ok im looking to build and boost either a dohc zc or d16y8. but my question is: is the zc worth a damn to build and boost and if so how much more of a head ache would it be to find all the right parts for it? i have heard they can be junk motors but i have never pushed mine that far so i dont know. im leaning towards the y8 but i already own the zc. it dont bother me if i have to spend a little bit of money to buy all the correct and quality parts. i just need a little input and opinions to kinda help make up my mind, in the end im looking to hopefully boost 18-20psi and make 250-300whp. thanx alot guys
Old 10-03-2005, 06:25 AM
Hybrid1990crx's Avatar
Re: better to boost a d16y8 or zc?
well if you are looking to run that much boost, than you are going to be looking at a fully built motor. so id just rock it with the ZC you have. Personally I hate those motors, but a freashly built motor is a built motor and will last as long as its done properly.
if i was gonna choose between and stock ZC and a stock y8 for boost, id choose the y8.
Old 10-03-2005, 12:55 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
you're looking at potentially running 20 psi. so either way you will need to rebuild, you & i both know that. it is a tough call because you bought you car with a ZC already in it. it's not like you choose to buy and spent the money for it. i suppose this is how i see it....
ZC pro: can get cams + cam gears and have the slightest bit more of adjustablity
ZC pro: you already have it, just have to rebuild
ZC con: not as much aftermarket support
VS.
y8 pro: aftermarket support
y8 con: you have to buy it before you can rebuild it. can possibly resell the ZC to help fund the rebuild
i hate to say it but we can not decide for you. different people build different engines for different reasons. you have to decide which engine is right for your reasons
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 10-03-2005, 08:43 PM
slipknotcraig133 slipknotcraig133 is offline
Send a message via AIM to slipknotcraig133
If it was me i would go y8. Aftermarket support is big on that motor compared to the zc. And you could build the y8 while you keep your zc in the car. Then when you get the motor done and it sell your zc to pay part of it off.
Got the car 1400
Need an H22a4 4000
Some Goodies to go Along With it 2000
Some Drag Slicks 750
Going to the Strip and Make V8's Say D*** Hondas PRICELESS
Old 10-03-2005, 09:33 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
you know if you concerned with the cost of a y8, then you dont have the money for this
Team Lonely Drivers
Old 10-04-2005, 12:56 PM
amy@af's Avatar
Re: Re: better to boost a d16y8 or zc?
this is a D & Z conversation....B on your way
j/k
Old 10-04-2005, 09:27 PM
lol you know im not getting a b im getting a h. But anyway here is a kit that i found for the d16y8 ryan check it out.
Got the car 1400
Need an H22a4 4000
Old 10-04-2005, 09:28 PM
https://www.prostreetonline.com/buy/...ck_turbo_kits/ my bad forgot to put the link in lol
Got the car 1400
Need an H22a4 4000
Old 10-05-2005, 12:32 AM
how much boost is the garrett t28 good for cause im looking to hit maybe hit 18-20psi and would a external wastegate be more appropriate?
Old 10-05-2005, 12:36 AM
i dont really know all that much about turbos but i know that with an external wastegate you have more boost adjustability.
Got the car 1400
Need an H22a4 4000
Old 10-05-2005, 12:24 PM
amy@af's Avatar
you're getting a b tranny...seriously tho, i'm just messing with you. techincally i am the owner of a b16 civic, i just perfer to drive the y8 civic (for reasons completely different than the subject of this thread, lol)
