Old 10-02-2005, 11:08 PM
ct91rs ct91rs is offline
Question Tie Rod Ends '98 Caravan
I'm going to be replacing the outer tie rod ends in my ma's '98 Caravan tomorrow, I have never worked on one of these vans before, anything I should be aware of?
“When a whole nation is roaring Patriotism at the top of its voice, I am fain to explore the cleanness of its hands and the purity of its heart.” - Ralph Waldo Emerson
Old 10-03-2005, 05:50 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Tie Rod Ends '98 Caravan
They are pretty standard. You will need a tie-rod tool or puller to get them loose once you have the nuts off. Mark their location on the sleeve so that you can get them back as close to where they were when you removed the old ones. You can do this with paint or a marker. Once you have the new ones on take to an alignment shop and have an alignment done. Regardless of how careful you are you just can't get them back in the exact same location.
Old 10-03-2005, 10:48 PM
eldiablo1100's Avatar
eldiablo1100 eldiablo1100 is offline
Send a message via AIM to eldiablo1100
when i replace outer tie rods, i like to count the revolutions it takes to unscrew it, then with the new one screw it in the same amount of turns, by doing that, usually the alignment will be just like it was before. but it never hurts to get your alignment checked when you finish anyway
Old 10-05-2005, 10:15 AM
Re: Re: Tie Rod Ends '98 Caravan
Thanks guys, it's going in for an alignment later this week, and changing them was a lot easier than I expected.
