Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 10-02-2005, 09:54 PM
papaturk papaturk is offline
Hard Starting, stalling & fuel smell
105,000 miles. Very infrequently the car is hard to start. Will turnover over however will run very rough for a few seconds. Garage gets filled with fuel smelling smoke. Progresivly getting worse. Today took three attempts. Car stalled on first. Is starting to burn a quart of oil every 2,500 miles. Any suggestions?
Old 10-02-2005, 10:14 PM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: Hard Starting, stalling & fuel smell
year/model?
ECT every been replaced?
Daily driver: 1995 Buick Regal Custom 3.8L 4T60-E 150K miles
Gone: 1994 Saturn SL2 1.9L MP3 168,666 miles
EPA 608 Universal Certification
EPA 609 Certification
Old 10-02-2005, 10:39 PM
Make and Model
1999 SL2. What is the ECT? I've almost all the maintaince and don't recall ever changing. Thanks.
Old 10-04-2005, 05:05 PM
burning 1qt/2000miles is average for the 1.9 engine, you are in good shape there.
the ECT is the engine coolant temp sensor, it tells the computer to run rich when the engine is cold, if it fails(common on the 1.9) the engine will run rich. one possible test is to disconnect it before starting the engine, then the computer should default to the reading from the intake air temp sensor, and start better if it is bad.
also can you determine if the smell/ smoke is coming from the tailpipe or from underhood?
