Old 10-02-2005, 08:53 PM
bull127 bull127 is offline
97 fuse box (under hood)
Ok I have searched and searched this forum and under my hood, is there even a fuse box under the hood of a 97 blazer? I read numerous posts about checking the fuses for my 4 wheel drive problem, but i can not locate any fuse box under the hood. TCCM fuse? to try a resest of the computer etc.
can someone tell me something about this please, none of the other posts about fuses or fuse boxes seem to pertain to a 97 mostly 98 and 96
thanks
dennis
Old 10-02-2005, 09:03 PM
mike1224's Avatar
mike1224 mike1224 is offline
Send a message via AIM to mike1224 Send a message via MSN to mike1224 Send a message via Yahoo to mike1224
Re: 97 fuse box (under hood)
its a black box on the drivers side, has a twist-off screw cap.
2002 Chevy S-10 ZR2
Originally Posted by balls_to_the_wall
Some people are alive only because its illegal to kill them.
Old 10-02-2005, 09:23 PM
Re: Re: 97 fuse box (under hood)
I just looked the only thing i see is a little black box with two twist off screw caps and it is a junction box for a group of wires with fusable links?
man this is frustrating the hell out of me lol...
Old 10-02-2005, 09:48 PM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
Did you check behind the Fuse cover on the side of the dash on the driver's side?
Old 10-02-2005, 10:08 PM
yeah i checked all those fuses, nothing that says anything about tccm, or any other ting to do with that, there is a 4x4 fuse. i tried it with that and it did nothing.
that is why i was curious if there is even a fuse box under the hood on a 97 because i sure can not find it. i am not an ignorant person, i am an electrical engineer but man does this make me feel very very low lol...
should have taken the advice from my father, dont get involved with 4 wheel drive.
i dont know man, but this whole thing is making me nuts
Old 10-03-2005, 06:40 AM
Exactly what is your problem?
Does 4x4 not engage?, do your selector lights work/flash?
It may be something as simple as a vacuum line disconnect or a hole
in the line. (Check all hoses that connect to the vacuum ball on the
underside of the hood-driver's side)
To reset your ECM, disconnect the negative battery terminal for at least 10 minutes.
Old 10-03-2005, 10:57 AM
the truck is stuck in 4 hi. press the 2 hi button and it doesnt engage, just blnks a few times and then goes right back to 4 hi, ive tried back up , neutral, slippery surface, checked all the vacuum hoses from actuator, i dont know what else to do. that is why i was lookin gor the fuse box under the hood, to see if i hd something blown there.
thanks for your time mike..
Dennis
Old 10-03-2005, 11:21 AM
Dennis
Wish I could have been more help. I know from previous experience the vacuum lines cause a lot of problems.
Here's a link to a similar problem, take a look at the last entry in the post. It might give you some insight.
http://www.automotiveforums.com/vbul...ing+4x4+lights
Good Luck
