Old 05-16-2002, 01:02 PM
bc4g bc4g is offline
APC intake
Ok guys I put an APC intake on the 1.5 only because i got it for 40 bucks but I noticed after I put it on I have had bad gas mileage I also have a 3'' exhaust with a 5'' tip do you think I running too lean with this set up?
Thanks
Chad
B C kit
motegi 15's
tenzo R seats
3'' exhaust 5'' tip
Old 05-16-2002, 01:13 PM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
try resetting your ecu?
w/ those minimal mods, I highly doubt you're running lean...
SOLD!
Old 05-16-2002, 01:42 PM
grrltoy grrltoy is offline
Send a message via AIM to grrltoy
I HAVE A CRAPPY INTAKE ALMOST SAME AS APC. BETTER THAN STOCK, BUT CAN'T BE MORE THAN 1-3 HP GAIN. NO CHANGE NOTICED IN GAS MILEAGE. PICKUP SUCKS, BUT ONCE I GET GOING, I CAN GET A LITTLE BIT OUT OF IT. GOT IT OFF EBAY FOR $21. CAN'T BEAT IT!!
"they sell us love as divinity when it's only a social obscenity"
Old 05-16-2002, 05:28 PM
Bleebdat Bleebdat is offline
Send a message via AIM to Bleebdat Send a message via Yahoo to Bleebdat
Bc the intake could be screwing the velocity of the air into your engine Im not for sure, but I had a friend who put a 3 1/2 pipe and filter on his teg, ruined his gas mileage and low end, but helped out higher in the rpm's.
Old 05-16-2002, 07:31 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
the 3" exhaust is way too big for our little 1.5's take it down to at most a 2.5" then reset your ecu and drive around again, it should run better.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 05-16-2002, 10:03 PM
Jmunk Jmunk is offline
Send a message via AIM to Jmunk
Exhaust
3" exhaust is way too big. Having pipe that big should make you car slow as hell off the line. If i were you i would get new exhaust and have someone do it in 2 inch. Someone just did a post a bit ago that i replied to on mandrel or crush bent exhaust. Go and read that before you do much of anything.
Old 05-19-2002, 06:07 PM
DarkImportGrey's Avatar
DarkImportGrey DarkImportGrey is offline
Send a message via AIM to DarkImportGrey Send a message via MSN to DarkImportGrey Send a message via Yahoo to DarkImportGrey
You don't need much more than a 2" exhaust on a 1.5L. Contrary to popular beliefs, too much back pressure and not enough back pressure are both bad things. Since you have such a large exhaust, the exhaust gasses don't move as fast, and get colder and slow down inside the pipe, causing the exhaust gas behind to have to push the gas ahead of it out, causing inefficiency and bad performance. Too small of a pipe and the exhaust gasses can't get out fast enough and it restricts engine performance. Get a mandrel bent 2" exhaust put on your car, and for god's sake take off that big ass tip.
Old 05-20-2002, 12:23 AM
Thanks for the info and yes the big ol tip will be coming off. I just hate to replace something no more than two years old but ya gotta do what ya gotta do 5zigen here I come.
Thanks
Chad
B C kit
motegi 15's
tenzo R seats
3'' exhaust 5'' tip
