Old 10-02-2005, 08:00 PM
ryanszpara's Avatar
ryanszpara ryanszpara is offline
Send a message via AIM to ryanszpara
headlight dissasembly on 2002
i was wondering if anyone knows how to dissasemble the headlights on a 2002 silverado safely (without breaking the clips)
I am not talking about removal, i am wondering about dissasembly -taking the clear plastic lense off of the entire assembly ....
Thanks for any input
PS-is there a type of sealant around the plastic clear lense?
I went muddin, and the lenses filled up with water, and now are just 100% mud...i ran water and windex throught the bulb hole, but the liquid just evaporates and leaves a lot of dirt. Any suggestions?
I want to be able to wipe the inside of the lense
Thanks
2002 Chevy Silverado
5.3 L v-8 4x4
Bought on 10-26-04
K & N Filter
4 Headlight mod
Fog Lights
FM 40 Series-dual turn downs
FUTURE PLANS:
3 inch lift
285/75 r16 BFG A/T s
Wheels? (american racing)
Old 10-02-2005, 08:46 PM
jethro_3's Avatar
jethro_3 jethro_3 is offline
Re: headlight dissasembly on 2002
Reading a thread on another forum and they stick the whole headlight in the oven at about 175*. Once it gets the black silicone warm you can pry the two pieces apart. Have your replacement silicone ready to reinstall.
God Luck
Old 10-02-2005, 09:25 PM
ryanszpara's Avatar
Re: Re: headlight dissasembly on 2002
God Luck
Awesome, i thought there was some sealant.....
How much/where can i find replacement silicon??
Also could you give me the www to the "other thread" you were reading?
Thanks alot man
5.3 L v-8 4x4
Bought on 10-26-04
K & N Filter
4 Headlight mod
Fog Lights
FUTURE PLANS:
3 inch lift
Old 10-02-2005, 09:58 PM
jethro_3's Avatar
I read it today and now I can't find it. It is either in SiveradoSS or PerformanceTruck forums.... That ticks me off that I can't find it.....
Sorry, I wiil continue to look
Old 10-02-2005, 11:47 PM
ryanszpara's Avatar
Thanks for the help man...the light that gets full of water and mud ( passanger side) is starting to yellow on me, so i gotta get it fixed
Thanks man
5.3 L v-8 4x4
Bought on 10-26-04
K & N Filter
4 Headlight mod
Fog Lights
FUTURE PLANS:
3 inch lift
Old 10-03-2005, 12:59 AM
jers99z jers99z is offline
Send a message via AIM to jers99z Send a message via MSN to jers99z Send a message via Yahoo to jers99z
Have you thought about getting some off ebay. They usually have new, aftermarket, and used ones. Just a thought.
99 Z-71 5.3 liter. Jet stage 2, volant cool air intake, flowmaster 40 series, billet grill, clear corners, chrome bed rails, pioneer cd player, Infinity Kappa speakers, silverstars.http://www.cardomain.com/ride/2094079
Old 10-03-2005, 08:50 AM
twomorestrokes's Avatar
twomorestrokes twomorestrokes is offline
What about just removing the assembly and cleaning? Remove the bulbs, put water in it, and clean, either with a rag or foam on a bent coat hanger. Or you could stuff a small wet rag in there with a little water and dish soap and shake it. Blow them out with compressed air afterward.
Just a couple of silly ideas, but seems easier than taking them apart and regluing...
'02 2500HD 6.0/4.10 Air Lift bags, 175 psi onboard air
Old 10-03-2005, 12:13 PM
misfitt006 misfitt006 is offline
Send a message via Yahoo to misfitt006
Seems to me that if you open them up to clean them that you'll sacrifce the integrity of the lenses and you'll have a repeat of the problem every time you go offroad with it. Might be better to do like they said above and buy some new ones....just my
Old 10-03-2005, 03:08 PM
chuck16's Avatar
chuck16 chuck16 is offline
WHat if you hold the light up Lense towards the sky and shove a hose inside it. Then water would splash off the lense and run down the reflective material and out the hole....
Must be some pretty thick mud.??
2008 GMC ACADIA
SLE Edition, 7 passenger model
I AM Canadian!!
Old 10-03-2005, 05:25 PM
jethro_3's Avatar
The factory silicone does not always seal in the outer corners, mine leaked on my '01 and I took clear silicone and fixed that after finding a brush that was long enough to bend and scrub the inside surface. The dirt gets baked on the inside with the heat from the headlights. No matter which way you go, new or repair, adding silicone will help.....
