Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 10-02-2005, 06:15 PM
nkelly nkelly is offline
Angry 96 explorer front end
I have a '96 explorer xlt that started to have a whirring noise come from the right front end. It increases with speed and is pretty loud. I am guessing that it is a front wheel bearing....anybody got any ideas?
Old 10-02-2005, 10:44 PM
asemstr asemstr is offline
Re: 96 explorer front end
Most likely a uneven treadpattern. Check the tire for a wave-like pattern on the edges.
IS IT FIXXED YET?!
Old 10-03-2005, 01:22 PM
Re: Re: 96 explorer front end
I do have some uneven wear on that side so I will have the tires rotated and see if it goes away...thanks.
Old 10-03-2005, 10:33 PM
It will not completly vanish it will just move to the new location. Make sure the tire has good air presure, and if the tire you move to the front starts to wear uneven you may need to have the alignment checked. If the wear is a alternateing shallow-deep-shallow (cupping) you need to check your shocks! Good Luck!
IS IT FIXXED YET?!
