Old 05-16-2002, 11:40 AM
grrltoy grrltoy is offline
Send a message via AIM to grrltoy
Royal Purple Synthetic Oil
Ok. I'm thinking about switching over to Royal Purple. Does anyone have any experience with it? Is it worth the $$$? Also, my ride has 56k. Is this a good time to change? and do I just do a regular change or should I do a complete flush first?
"they sell us love as divinity when it's only a social obscenity"
Old 05-16-2002, 12:18 PM
SleeperTeg's Avatar
SleeperTeg SleeperTeg is offline
Royal Purple rocks. I get it by the 5 gal bucket!!
As for whether it is good for you......what do you use now?
Gretchen
Off Topic Morning Crew
Old 05-16-2002, 01:25 PM
I've just been using Penzoil. I've been thinking about changing to synthetic, but I wasn't sure what kind. I heard good things online about Royal Purple, but I wanted to get someone's first hand opinion. ARe there any cons of synthetic?
Old 05-16-2002, 01:47 PM
SleeperTeg's Avatar
The cons to synth are price and leaky seals in higher mileage engines. The seals leak due to higher viscosity. With 50-60k miles you should be good to go.
Gretchen
Old 06-01-2002, 10:15 PM
russtang russtang is offline
Send a message via ICQ to russtang Send a message via AIM to russtang Send a message via Yahoo to russtang
Thumbs up synthetic fluids
I've always used synthetics in my cars.I always notice an increase in HP on the initial change. I also have started using Prolong too and it seems to make a difference {could be my imagination}. I have Royal Purple in my tranny now. No problems as of yet. Smoother shifting, combined with my new Neuspeed short shift kit. We'll see how it goes in the long haul as I just replaced the fuids this morning.....Russtang, blue type s RSX
Old 06-02-2002, 11:34 AM
thanks!!!
Old 06-02-2002, 10:10 PM
GSteg's Avatar
GSteg GSteg is offline
Send a message via AIM to GSteg
i'm afraid to find out how much it costed you..
Old 06-03-2002, 05:51 PM
Frostbyte Frostbyte is offline
Send a message via ICQ to Frostbyte
I have never used Royal Purple but I use the Mobil 1 Synthetic and it works great.
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
JIC Magic Front and Rear Strut Bars
Slotted and Cross-drilled Rotors
S/S Brake Lines
Pivot Lazy eye controller
Blitz LM Intake
Blitz D1 Spec Turbo Timer
Soon to come:
Sard 550cc Injectors
Blitz Nur Spec Exhaust
Blitz Down pipe
HKS FMIC
http://www.driftmonkey.com (Part Owner)
Old 06-05-2002, 11:46 PM
SleeperTeg's Avatar
My uncle works for a power plant and that is all they use to lube pumps and bushings.....i have no idea what it retails for.
Gretchen
Old 06-07-2002, 01:24 PM
Marasmus Marasmus is offline
Send a message via Yahoo to Marasmus
speaking of synthetic switchovers
I'm at 33,000 mi and I've been thinking of switching from ole'fashioned oil to synthetic (probably mobil 1). but I've been afraid of the seal leakage... Are there any things that can be done to avoid replacing the seals? I heard of people doing half-regular half-synthetic for a few thousand miles before going full-synth, but I'm not sure if that's just an old wives' tale or if it actually makes a difference. Any suggestions on this?
Old 06-07-2002, 05:02 PM
Re: speaking of synthetic switchovers
To my understanding you cannot mix Reg and Synth oil because they do not mix with each other. One oil will float on top of the other one oil is heavier then the other.
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
S/S Brake Lines
Blitz LM Intake
Soon to come:
Blitz Down pipe
HKS FMIC
Old 06-09-2002, 08:09 PM
Re: Re: speaking of synthetic switchovers
That makes very good sense.. two weights of oil in the same engine would certainly have peculiar effects!
Is it the head gasket that most commonly suffers from leakage from synthetic swaps, or is it another gasket/seal? I'm just trying to figure out my worst-case-scenario costs for switching to synth.
Old 06-12-2002, 12:31 AM
Tominos Tominos is offline
i think maybe what he is talking about is synthetic blend. but also, i heard alot of people say that you can't switch to synthetic if you did not start with it, it eats your gaskets. but then again i've heard it's the other way around, you can't switch from synthetic to regular. anyone have any info on this?
Old 06-13-2002, 08:19 AM
SleeperTeg's Avatar
Re: Re: Re: speaking of synthetic switchovers
It dosent 'eat' your gaskets. It is just a thinner oil and has different detergents so it kinda seeps by where your other oil did not. And no, it is no your head gasket that it gets by, it is more like you oil pan, valve cover, etc....
Hope this helps.
Gretchen
Old 07-01-2002, 08:16 AM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
not that im a petroleum engineer or anything, but i do work at an fast lube shop. as far as not being able to mix the two, just look at syntec blend as an example. its part GTX and part syntec. it works fine, just doesnt hold up as well in severe driving as syntec does. also, about not being able to go back to a conventional oil after using a synthetic, once again thats false. you can put either one in, again, the example being blend oils. but you will notice differences in your engines performance. syntec comes in 5w50, which means that it can handle a greater range of temperatures. another thing that is good about synthetic is its ability to bond to engine parts better. when you first start a cold engine, conventional oil, for the most part, has settle down in the pan. with synthetics, they have an opposite charge from the metal in your block, so they cling to it a lot better. this prevents dry starting, or what happens when you crank a cold engine and the oil pump has to hurry to get oil to your valves. we see it all the time at work. we drain the old oil, take off the filter, and pump fresh oil in and new filter, but then when we start the car, it has a slight valve tap for about 3 seconds. this is because for those three seconds, the oil pump must fill the filter first before supplying oil to the top end. now when you start up in the morning, your filter already has oil in it, but the effect is the same, for a few seconds the top end is virtually oil-less. bottom line is, synthetics work, and if you have an older engine, they make it feel less old, but of course with a 5w50, there is a greater chance of it seeping through the pan gasket than with a conventional 20w50 or something in that order that is usually used on engines with high mileage. if synthetics did destroy engines, then i doubt that chevrolet would not REQUIRE that all newer corvettes use mobil 1 and nothing else.
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
