Go Back   Automotive Forums Car Chat > Hyundai > Sonata
Old 10-02-2005, 04:36 PM
quickywd01 quickywd01 is offline
99 gls rear suspension
I need a right rear knuckle axle carrier assembly and a right rear hub assembly with bearing. There is no abs and there are disc brakes. Are there any aftermarket companies that carry these parts? And if anyone knows where I can get these please let me know. I've tried sevral junkyards and they don't even have the car. I found one sonata but it had drums in the rear and I think those parts are different, can anyone confirm this?
Nissan, Subi, Yoter, Ford
Old 10-03-2005, 07:58 AM
I looked at hmaserivce webtech and under both the v6 an 4cyl views of the rear suspension it is the same picture. I need the knuckle axle carrier assembly, the thing that mounts to the upper arm and assist arm. So from what I can see it is the same part. Can someone look at this and tell me if I'm right.
Old 10-03-2005, 09:42 PM
Re: 99 gls rear suspension
If I call a hyundai dealership parts department will they confirm this or will they not want to tell me? lowsonoma1999 do you know anything about how the parts department works?
Old 10-04-2005, 12:15 PM
lowsonoma1999's Avatar
lowsonoma1999 lowsonoma1999 is offline
Authorized Vendor
Send a message via AIM to lowsonoma1999
The carrier doesn't matter between the 4cyl and V6. It does make a difference between disk and drum, and with or without abs. The V6 only came with disk brakes, and some 4cyl came with disk, but mostly drum. For the carrier you need, part # is 52720-38200. List price is $507.48. The rear hub part # is 52730-38003, which lists at $212.48. I'll sell you both for $550 plus freight. I have the hub, but not the carrier, so it'll take me a couple days to get that. I don't know where you are at, so freight might be a bit. The carrier does have some weight to it.
John Nance
Parts Manager
Terry Lee Hyundai
17665 Terry Lee Crossing
Noblesville, IN 46060
Old 10-12-2005, 09:49 AM
Thank you and I would like that. I live in Parsippany, New Jersey. If you could inform me of how much shipping that would be great. I'm trying to get my car fixed a.s.a.p. for school. Leave a reply here or PM me or email me, thank you. ONe quick question are these parts new or used?
Old 10-12-2005, 10:12 AM
Authorized Vendor
Re: Re: 99 gls rear suspension
Shipping should be about $10-$15 or so. I figured box should weigh probably 15-20 lbs. Give me a call and let me know.
John Nance
Parts Manager
Terry Lee Hyundai
Old 10-12-2005, 06:29 PM
Re: Re: Re: 99 gls rear suspension
