Old 10-02-2005, 04:20 PM
biglogonafrogbig biglogonafrogbig is offline
Starting Problem, only getting worse
I have an 88 chevy 5.7, and the thing is sometimes when i go to start it ,I turn the key and nothing happens. In the past it only did this about every other time, then it started doing it every time. But now it takes 5 to 6 trys for it to turn over. Do yall think it might be a bad starter or just a bad connection at the starter, because its fine at the battery. Its a brand new battery with 875 cold cranking amps so the battery shouldn't be a problem. I'm just worried that at this rate it one day it might not start at all , thanks
Old 10-18-2005, 09:51 PM
reiling3 reiling3 is offline
I had the same problem with my '89. Turned out being bad battery cables. This would be a good place to start.
Old 10-19-2005, 09:19 AM
Fireplug Fireplug is offline
Re: Starting Problem, only getting worse
It sounds like a dead spot in the starter. Very common GM problem. But I would check the battery cables first , remove them from the battery and clean them , reinstall them and make sure they are tight, then test the battery to make sure its good, then check the wires on the starter ,if everything checks out then replace the starter
Old 10-19-2005, 04:21 PM
broughy84's Avatar
broughy84 broughy84 is offline
i mean
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
