daytime running lights
is there anyway of disconnecting the daytime running lights on my 96 s10 blazer? thank you
Re: daytime running lights
1998 BLAZER LS Vin-W 4Dr 2wd 2004 Cavalier LS 4Dr 2.2 Ecotec "Good Part's ain't Cheap--Cheap Parts ain't Good" |
I have a fuse under the hood in the fuse block that says DRL next to it, I pull that fuse and no more day time running lights.
By the way I have a 98
2002 Pontiac Gram Am K&N Air Filter Mobil1 5W-30 Extended 15K 2 JL Audio 12" Subs Sealed JL Audio Box Coustic 400 Watt Class D Mono Amp Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner Polk DB750 6.5" all around Yankees Suck!!!!!!!! |
If you step on the emergency brake down to one click or two it turns off the DRL and is not enough to engage the parking brake, this is a factory feature made specifically for turning off the DRL.
All I had to do in my '96 is remove the DRL fuse from the panel next to the drivers side door. FYI, the fuse is also for factory foglamps.
Foggy or not, ya gotta rock the fog lamps whenever possible.
More lights = more cool |
Re: Re: daytime running lights
When you take the panel off, there should be a label on it telling you what fuses are what. The fuse you want to pull is DRL/Fog.
Re: Re: Re: daytime running lights
Glad to help.
I would love to know why would someone disengage the DRL. Unless you are a CIA, PI, FBI or DEA agent who needs to follow someone covertly like james bond no need to turn them off. I wish I could make my fogs come on with the DRL during the day. More lights are definately better
For that matter, take a magnet to the back of your driver's license as well! If he is going to write you a ticket, make him punch in the info manually instead of just swiping the license like a credit card! Again, why make it easy for him! |
I pulled the fuse for my DRL's because a lot of the time I leave the truck in ACC position for the ignition when I need more then just the radio and when the DRL's come on it really drains the batter fast!
I just don't see the reason for having the headlights on all the time. You're just going to burn them out faster.
Besides, I like pretending to be James Bond once in a while.
