Go Back   Automotive Forums Car Chat > Dodge > Durango
Old 10-02-2005, 03:24 PM
12sec5ltr 12sec5ltr is offline
Bad intake gasket, If I fix it will I get better MPG
just wondering if I fixed the sucking intake gasket if it would give me a little better gas mileage. I have a 99 with a 5.2 What are the epa estimates on these things anyway. I get about 12 mpg highway without my trailer and 10 mpg pulling a 6x1o enclosed trailer with a 550 lb four wheeler in it. trailer probably weighs 1100 lbs. I know these things don't get great gas mileage but 12 on the highway come on.
Old 10-03-2005, 06:57 AM
DurangoDave DurangoDave is offline
mileage
My best ever highway: 15.8mpg. (1999 5.2, not towing).
Old 10-04-2005, 12:30 AM
scrindy scrindy is offline
Re: Bad intake gasket, If I fix it will I get better MPG
Yes it will help on your Fuel economy. Your sucking more air and changing you fuel ratio. I am not sure but you may have burned up you O2 sensor as well. Not sure if it will trigger a code. And thast will keep you in cold start or closed loop in the ECM
Hope it helps.
Scrindy
Old 10-07-2005, 05:50 PM
Re: Re: Bad intake gasket, If I fix it will I get better MPG
Hope it helps.
Scrindy
Thanks, I'll check the O2 sensor out after I'm done. I have a professional scan tool that can check the sensors condition
Old 11-24-2005, 12:34 AM
Re: Re: Re: Bad intake gasket, If I fix it will I get better MPG
Getting about 14.5 on the highway now after the intake fix. so I did get better. Plus now I'm not spending money on two quarts of oil every gas fill up so all in all it was a sucess.
