Procedure to remove cargo area interior panels?
I need to remove the cargo area right side panel so that I can wire in a six wire trailer kit. I don't see any screws and do not want to break any snaps.
Can anyone advise of the proper procedure to remove this panel? I need to tap into the tail/turn signal wires and the 12v power. There is a 12v cig plug in the back, so I could easily tap into all the needed wires if I can just get the panel off without damaging it. - Cole |
Cole, an aftermarket trailer wiring kit *should* be plug & play for your 2001. It was for the 2002 and 2003 in my family. The factory plug is coiled and taped to a main harness behind the panel near the jack compartment. Get your fingers behind the panel near the tailgate weather stripping and give it a yank. The panel pops right out. You will see the harness taped with blue tape. Uncoil it and shove the connector thru the opening in the jack compartment so you can get at it when you need it.
G/luck Joel
2016 Subaru Forester 2.5i base CVT 2016 Nissan Quest SV |
Cole,
I recently installed the Isuzu wiring kit. It came with a 4-pin setup. Rodeo02 is correct, the factory harness receptacle is already wired in your truck. There is also a pop-out plastic grommet down in the fenderwell below the level of the interior cargo floor. You'll need a mirror to see it but it is easily felt. The Isuzu kit comes with a rubber grommet with a hole in it. Lube the replacement to get it in easier. To remove the side cargo panel, it may also be easier to first remove the cargo "lip" on the floor. There are three snap-in plastic clips towards the rear, there is another snap-in plastic clip adjacent to the cigar lighter thing-a-ma-bobber. The pocket is held to the frame by two clips. Finally there are several plastic "tongues" in the front of the panel that slide out when the panel is pulled rearward. What Rodeo do you have? I have a 02' Rodeo Sport. There may be a dissimilarity in the body panels....but hopefully this'll give you a hand. I've dismantled the entire interior of my RS twice..... That rear panel is the easiest part IMO. Good Luck! -johann schuster
"Little Blue War Pony!!"-2002 Isuzu Rodeo Sport Sparkly-Blue 3.2v6 2wd softtop....0-60 8.0secs =) Last edited by Joihan777; 10-03-2005 at 04:46 PM. |
Re: Procedure to remove cargo area interior panels?
-Ryan Isuzu Moderator Car Show Tips Operations manager with a results-driven passion for process improvement FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd |
Thanks for the guidance
Hey -- thanks for the info folks and the pics. I should be able to get that puppy out and get hooked up.
Regards, Cole |
