Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 10-02-2005, 10:50 AM
NickF829 NickF829 is offline
Rear doors squeak when opening...
and not like a " lube it a little " kind of squeak, because i've lubed the hinges with everything i can find in my garage and it still squeaks horribly every time you open the 2 back doors(not the back hatch, but the 2nd row seat doors) anyone have this same problem? is there a special lube I should use or what. its pretty annoying
it is a 2001 yukon slt
Old 10-04-2005, 02:56 PM
chief11 chief11 is offline
Re: Rear doors squeak when opening...
The oversized weather stripping is often the culprit. Try putting some silicone or other lubricant on the rubber...see if that helps.
Old 10-04-2005, 09:29 PM
transgta transgta is offline
Mine does it to. The squeak comes out of the slide that goes into the truck but i cant stop it either.
