Go Back   Automotive Forums Car Chat > Volkswagen > Passat
Old 10-02-2005, 08:43 AM
joker12usa joker12usa is offline
Changing the oil in a 1.8T engine
Where is the oil drain plug located on this engine. I looked for it yesterday but could not find it. There is a black flat area that looks like the trans.
Old 10-02-2005, 12:50 PM
Duncan1 Duncan1 is offline
Re: Changing the oil in a 1.8T engine
Take the black undertray off and you will find it. Make sure you don't drain the tranny!!!!!!!!!!!!!!!
Old 10-02-2005, 05:13 PM
Re: Re: Changing the oil in a 1.8T engine
The black updertray is held on with about a million star screws correct?
Or do you mean the black plastic air dam in from of it which looks like it cools the tranny or what I think is it tranny?
Old 10-02-2005, 05:49 PM
Question Re: Re: Re: Changing the oil in a 1.8T engine
Originally Posted by joker12usa
Is the black updertray held on with about a million star screws or is that the tranny?
Or do you mean the black plastic in front of it which looks like it cools the tranny or what I think is it tranny?
I looked under the black plastic and there is a screw there that might be the drain plug. If it is, I may just cut a hole in the plastic rather than drop that every time the oil is changed.
Also, to change the oil filter it looks like the brake fluid container needs to be moved. Or is there another trick? My last VW was a 1969 Bug and it was a lot easier to do maintenance on it!! Thanks for your help!
Old 10-04-2005, 02:40 PM
Re: Re: Re: Re: Changing the oil in a 1.8T engine
The best way to get to the filter is to loosen the coolant reservoir and to lift it out of the way....
