Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '83 - '90
Old 10-02-2005, 08:06 AM
peter nugent peter nugent is offline
cannot select right gears on my '88 Jetta
I cannot select the right gears on my '88 Jetta-What is wrong and can it be fixed?
Old 10-02-2005, 08:07 AM
Re: cannot select right gears on my '88 Jetta
I cannot select the right gears on my '88 Jetta-I have driven it fine this past week but now cannot select gears. The gearstick is floppy. What is wrong and can it be fixed?
Old 10-07-2005, 02:36 PM
daveva daveva is offline
i had that problem on my 87 jetta gl. it was a bushing on the shift linkage. i found that i could rarely get 1st, and it was really hard to, and for 5, id be hitting third all the time. take a look at the shift linkage, and if it was the same as my car, a rubber bushing popped out. instead of replacing it, i just greased it up really good and popped it back in instead of buying a new bushing. hope this helps you.
Old 10-08-2005, 02:05 PM
boschmann boschmann is offline
There are also two metal rods with plastic ends that commonly break. They are commonly available.
