Go Back   Automotive Forums Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 10-02-2005, 02:07 AM
rav4t rav4t is offline
how to change tranny oil?
What is the procedure to do tranny oil change?
thankss
Old 10-02-2005, 11:12 AM
OffroadX OffroadX is offline
Send a message via AIM to OffroadX
Re: how to change tranny oil?
This should be in the drivetrain section.
Manual or automatic?
Manual: remove the fill plug on the side of the transmission. Remove the drain plug. Replace the drain plug. Add GL4 ONLY 75W90 (or GL4/5 synthetic) until it reaches the fill hole. Replace the fill plug.
Automatic: Raise the right front of the vehicle. Remove the drain plug from the pan. Measure the amount that comes out (about 5 quarts with the RF raised as noted above). Replace the drain plug. Use a long narrow-neck funnel to add the same amount of fluid via the tranny dipstick tube. Measure and add more as needed.
When did you last check your spare tire's pressure?
